[Z06] What did you do to your Z06 TODAY??
Old Jun 3, 2017 | 04:11 AM
  #3781
Scotty2000SS's Avatar
Scotty2000SS
Originally Posted by Nokones
I had Abel Chevrolet replaced my valve springs, all the cooling system hoses and coolant, belts, spark plugs, oil change, oil pan gaskets, and both motor mounts on my 2003 ZO6.
I love Abel. They installed my mini twin. Rich is the man
Old Jun 3, 2017 | 09:52 AM
  #3782
mwestc5's Avatar
mwestc5
Washed It
Took It Out For A 50 Mile Drive On The Interstate In A Nice Pouring Rain
Got It Home & Squeegeed it Dry
And Because I had Nothing Else To Do For 3 Minutes Replaced The Air Filter
Old Jun 3, 2017 | 11:59 PM
  #3783
harryk387's Avatar
harryk387
just came back from my first trip ever to the dragstrip. I took my 2004 Corvette Z06 that's putting out approximately 450 hp to the wheels and 430 rwtq. Toyo R888 all 4 corners. 275/40/17 up front, 305/35/18 in the rear. I was expecting, with my amateur driving, somewhere in the low 12 second to high 11 second range. I wasn't even close. It's funny and disappointing at the same time, I definitely have some work to do on my end.
I ranged between 2.242 and 2.470 for my 60 foot time, which I know is terrible. ET ranged between 12.818 to 13.981 ( I spun really bad off the line on this run). And my trap speed ranged from 112.57-114.81.
With these numbers, what's the best do you guys think this car can do with a seasoned driver behind the wheel?
Also, I would love to hear some suggestions on how to lower these times especially my 60 foot
Old Jun 4, 2017 | 03:06 AM
  #3784
Potent68's Avatar
Potent68
FWIW I had my '02 Z06 at the track last night. It's bone stock and I ran a personal best of 12.649 at 113.60 with a 2.115 60'. The "fast list" has stock cars in the high 11's.
Old Jun 4, 2017 | 02:42 PM
  #3785
C6Z06Silverbullet's Avatar
C6Z06Silverbullet
Installed LED driving lights and interior lights. Did the full treatment. Washed it, clay bar, sealed the glass, polished, waxed. Adams polishes are the ****! I dont know how I used anything else before.
Old Jun 4, 2017 | 10:33 PM
  #3786
harryk387's Avatar
harryk387
Took a drive down to Malibu and went up and down Latigo Canyon. First time I did canyon driving and while it was very fun, I got extremely car sick unfortunately. Shame since I really enjoyed the drive despite the motion sickness
Here's a nice pic I took while I took a break to recover from the motion sickness lol
Old Jun 4, 2017 | 11:52 PM
  #3787
SneakiestSnake's Avatar
SneakiestSnake
1st Gear
Put in my MGW short shifter. Awesome product, can't recommend it enough!
Old Jun 5, 2017 | 06:36 AM
  #3788
Spaceme1117's Avatar
Spaceme1117
Nice. I should be getting my MGW shifter tomorrow. What shift **** are you using?
Old Jun 5, 2017 | 11:35 AM
  #3789
Moto One's Avatar
Moto One
Waiting for new (off eBay) torque tube (going to use for parts) to arrive. To relive to boredom I'm going to replace a failing oil presser sending unit.
Mark.
Old Jun 5, 2017 | 12:12 PM
  #3790
gtturbo88's Avatar
gtturbo88
I spent the better part of the weekend installing the Tick adjustable master cylinder. Not done yet I'll keep you posted
Old Jun 5, 2017 | 06:01 PM
  #3791
GhostC5Z's Avatar
GhostC5Z
Swapped out the yellow springs and instantly gained peace of mind every time I fire it up now.
Old Jun 5, 2017 | 06:05 PM
  #3792
Georgies's Avatar
Georgies
Bro something isnt right. You should be trapping WAY higher considering all the work and quality parts that are into your car. Maybe your just launching too hard?
Old Jun 5, 2017 | 06:26 PM
  #3793
harryk387's Avatar
harryk387
Doubt I'm launching too hard. Trust me I babied it off the line. I'm with you, I feel like something is way off, whether that be because of the driver or something mechanical. I know I'm Running stock fuel injectors at around 90% of their capacity and I'm also running my stock clutch (which is still holding fine with no issues, slipping or Pedal sticking to the floor) would either of those two things be holding me back?
Old Jun 5, 2017 | 11:12 PM
  #3794
oneandgone's Avatar
oneandgone
Today was headlight gear kit day for me. SO glad to not hear it grind any more. I bought kits for both sides, but have only done one for now. I anticipate the next one to take half as long. Also, a quick car wash and checked all codes in the dic for the first time. I keep getting abs/trac lights after a car wash. LF wheel speed sensor code obtained. Next step is to check grounds.
Old Jun 5, 2017 | 11:33 PM
  #3795
Georgies's Avatar
Georgies
I dont know man its hard to tell.. do you feel that the car just wont fo any faster?? Go back this week end and try to do back to back passes and try different things. Dont worry about the car, you bought it and spent decent coin to go faster! Keep trying and come back with more info!
Good luck!
Old Jun 6, 2017 | 10:54 AM
  #3796
Moto One's Avatar
Moto One
Off to find a machine shop, eBay TT was a peace of S*^$. well take your chances.
Mark.
Old Jun 6, 2017 | 12:47 PM
  #3797
C6Z06Silverbullet
Good luck!
Doubtful
To What did you do to your Z06 TODAY??
Old Jun 6, 2017 | 12:49 PM
  #3798
C6Z06Silverbullet
Originally Posted by C6Z06Silverbullet
Doubtful
Sorry replied the the wrong thread
Old Jun 6, 2017 | 01:41 PM
  #3799
Stroker87's Avatar
Stroker87
you need a tire if you really want a better time! your launch technique needs some work slower your clutch release to start with play with tire pressure, are you shifting fast or granny shifting the car? when i was 450ish hp i was running upper 11's around 118mph with 1.7x 60's (best of 11.6 @ 119mph with a 1.68 60ft)
you need a sticky tire, get the launch down and shift as fast as you can bottom line is the harder you push the car the better time you'll see but if you push it to hard something will let go so it comes down to hot bad do you want that killer time slip!
Old Jun 6, 2017 | 10:13 PM
  #3800
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Wrapped my keyfob (got the wrap on ebay).​​​ Stock fob looks cheap plus the wrap will help protect it. My Z is Torch Red so bought red carbon fiber look wrap to complement the car.
