A new, affordable approach to Bullet Proofing the IRS
Now I acquired a New project corvette and wish to make it a solid 8 second, possibly 7 second street car with Stock Suspension to compete in a few classes around my area. I could do the tried and true way of the 12 bolt conversion, but after racing with my c6 vette against some of the newer 2015 and up mustangs, I realized those guys are running Stock untouched IRSs and doing 8 second quarter miles.
Surely it wouldnt be hard to use what they got in our C3's. they are ford 8.8's thay they dub the super 8.8 because they now are 34 spline carrier trac loc differentials. they are proven to be very strong.
then the next part of the equation is the weak outer stubs and wheel bearings. I know C7 corvette rear wheel hubs are cheap, about 75 bucks each on rock auto. They are 33 splined.
so you would no longer need the cast wheel bearing housing, welding a plate to adapt the hub to the trailing arm, you would have to fab up lower strut mounts attached to the trailing arm and you would have to make tabs on the trailing arm to bolt the calipers to.
then its the fab work to make the ford 8.8 bolt into the c3 which is a matter of brackets.
I already called The Drive Shaft Shop, the people who make all the 1000-1700 hp rated CV axles for C 5,6,7 corvettes,along with 1700 hp axles for 2015 mustangs. they said they can make 1000 hp axles for around 1000 bucks for this application and 1700 hp axles for $1699.
mustang differentials sell used for around 400-500 bucks on ebay, or a brand new mustang iron 3.55 gear 8.8 is 720 bucks. you would need to swap out the front pinion yoke to a normal 1330 yoke or up grade to 1350. they are about 100 bucks.
so all said and done, $720 for a diff, $150 for C7 rear hubs, $1000 for CV axles rated for 1000 hp and $100 for the 1350 yoke. $1970 in parts and then the metal fab work to mount everything.
Popular Reply
Moser shortened the axles for me. I’ve put some miles on the setup and made many hits on the street with 275 pro radials with no hiccups. Even with a pretty aggressive 1-2 shift on nitrous nothing has shaken loose yet. Haven’t made it to the track for the ultimate test of a dead hook on nitrous. The setup has taken the abuse I’ve given it on the street and i have no reason to suspect it won’t live at the track too.
JIM
Not sure what you mean by thrust loads and how its any different from any other IRS design. do you mean the transverse spring perch? I plan on using coil overs for my design, but a spring perch can be easily added, just make it integral to the upper crossmember rather then part of the 8.8.
Factory Five had three rear suspension setups to choose from, an IRS, a three link and four link.
The three link was actually used more in their road race car versions than the IRS.
Here are some photos from their website gallery.
IRS
Three Link
Four Link
I've got a Dana 60 housing from a Hemi car made into an IRS under mine. Took a little fab work to install but it's been there for many years without touching it.
JIM
