do you have a sight glass on the high side??? fill it until the small bubbles go away, usually around 3 cans(?). should say on a decal somewhere about how much if you were weighing it. You are certified to be working with R-12 , right?
if you are needing to charge this unit, have you looked for, leaks??? New o-rings are probably needed to start with. R-12 leaks have to be found before the unit can be charged.
