If There is a Bolt, There Should Be a Nut...Right?
Old Mar 21, 2018 | 09:33 PM
seijack's Avatar
seijack
Default If There is a Bolt, There Should Be a Nut...Right?
I was finishing up my oil change on my car tonight and wiping down a few items when I noticed a couple of bolts that look like they should have nuts on them. I looked at them a little closer and it looks like these bolts are the engine mount bolts that go thru the engine cradle. Hmmm, shouldn't there be nuts on them?? Seems odd..
I have owned the car since it had 3800 miles on it. I bought it from the original owner who was pretty meticulous like myself...I have never heard any noises under heavy acceleration.. Can anyone verify this condition on your car?
2008 C6 A6 Z51,
Old Mar 21, 2018 | 09:45 PM
RobJoy's Avatar
RobJoy
I know that my leaf spring bolt doesn't have a nut on it but the spring has so much pressure on it I doubt it would need one. But, this looks like it seriously needs a bolt if it holds the engine to the subframe.
Old Mar 21, 2018 | 09:52 PM
EVRose's Avatar
EVRose
According to this photo I found on this forum there should be nuts on those bolts.
Old Mar 21, 2018 | 09:55 PM
8SPD Z51's Avatar
8SPD Z51
[QUOTE=seijack;1596832712]I was finishing up my oil change on my car tonight and wiping down a few items when I noticed a couple of bolts that look like they should have nuts on them. I looked at them a little closer and it looks like these bolts are the engine mount bolts that go thru the engine cradle. Hmmm, shouldn't there be nuts on them?? Seems odd..
I have a C6 on the lift in the garage and just had a look.....yes there are nuts on them.
Old Mar 21, 2018 | 11:05 PM
buckmeister2's Avatar
buckmeister2
You can also tell by the surface wear that there were nuts on them.
Old Mar 21, 2018 | 11:40 PM
CHEV AGAIN's Avatar
CHEV AGAIN
I wouldn’t worry about it too much, the hood will hold the engine in there.. 😳
I’d get some nutz on there. 👍
Mark
Old Mar 22, 2018 | 03:06 AM
Mlcharlestonsc's Avatar
Mlcharlestonsc
Must have been a Monday car.. lol
Old Mar 22, 2018 | 05:56 AM
Elvis beltran's Avatar
Elvis beltran
Wow were did they go have any work done?
Old Mar 22, 2018 | 07:37 AM
Corvette_Ed's Avatar
Corvette_Ed
Did someone say nuts?
Old Mar 22, 2018 | 07:55 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
What kind of work have you had done on the car since owning it w. 3800 miles? If nothing more than oil changes, I'd ask the prior, meticulous owner what he had done. Tell us what happens.
Old Mar 22, 2018 | 08:55 AM
itomh's Avatar
itomh
You can tell there use to be a nut there from the marks that were left behind, any chance that that isn't the original engine?
Old Mar 22, 2018 | 09:15 AM
EVRose's Avatar
EVRose
Maybe the previous owner had the balancer replaced and the mechanic dropped the cradle instead of moving the steering rack.
Old Mar 22, 2018 | 09:42 AM
VETYGUD's Avatar
VETYGUD
My leaky motor mount before I replaced them on my 2009. Torqued new Hinson mounts to 50 ft-lbs.
Old Mar 22, 2018 | 11:58 AM
seijack's Avatar
seijack
[QUOTE=8SPD Z51;1596832872]
Thanks For verifying.
SOOO FUNNNNY....I guess the squirrel took mine..LOL
I have no idea. I may have to call the original owner and find out. I am going to have a service history run on the car tonight when I pick up my new nuts....
Originally Posted by itomh
Any chance that that isn't the original engine?
I do not think that is the issue, more than likely it was done while working on the car. The question is what were they repairing, HB, Oil Pan leak, Steering rack?? If they replace the oil pan gasket they did not do a very good job as it still seeps a tad bit of oil!!
Thanks for the info, do you think that 50ft-lbs would also be the spec for the stock mounts?
Thanks all for the information, I guess I will find out more tonight when I run the service history at the dealer.
To Be Continued.......
Old Mar 22, 2018 | 01:13 PM
BlindSpot's Avatar
BlindSpot
Oil pan gasket is a likely candidate that led to this. I did an oil pan gasket on a C6 after the dealership basically hosed it. They could have done it and misdiagnosed the leak anyway, then left the nuts off. Dealerships can get "in a hurry" when they're trying to make money on warranty work, which was the case with the one I did.
Not likely the HB as most who change the HB don't remove those nuts all the way.
Old Mar 22, 2018 | 01:29 PM
Landru's Avatar
Landru
Originally Posted by BlindSpot
Oil pan gasket is a likely candidate that led to this. I did an oil pan gasket on a C6 after the dealership basically hosed it. They could have done it and misdiagnosed the leak anyway, then left the nuts off. Dealerships can get "in a hurry" when they're trying to make money on warranty work, which was the case with the one I did...Not likely the HB as most who change the HB don't remove those nuts all the way.
Plausible.
Done under warranty it'll show on GMVIS.
Might be as simple as factory never tightened to spec, missed it, and they simply vibrated off. A factory screw-up.
Good thing OP caught it, although it might've motored off into the sunset for years unnoticed until new mounts were needed.
Old Mar 22, 2018 | 03:50 PM
VETYGUD's Avatar
VETYGUD
"Thanks for the info, do you think that 50ft-lbs would also be the spec for the stock mounts?"
That was Hinson's torque specs (50 ft-lbs) using the oem nut. GM specs are 48 ft-lbs for the upper and lower motor mount, nut to stud, at the upper side of the bracket and through the cradle. The motor mount brackets to engine block are 37 ft-lbs.
To If There is a Bolt, There Should Be a Nut...Right?
Old Mar 22, 2018 | 04:06 PM
Cooter Tech's Avatar
Cooter Tech
Check to see what is on the opposite side, make sure it is there and tight. I hate it when I have nuts, screws, bolts and washers left over from a project!
Old Mar 22, 2018 | 06:29 PM
RobJoy's Avatar
RobJoy
Yeah. Seems the only time the dealer mechanic gets in a hurry is when doing warranty work. The rest of the time they are slow as molasses in January.
Old Mar 22, 2018 | 07:13 PM
JasonAndrew's Avatar
JasonAndrew
flange nuts
