[C2] What do these numbers say about the cam?
Chevy spec says 350HP at 5800 rpm, torque 360 @ 3600 for the L-79. I know those are flywheel numbers with no accessories, so I'm not expecting anything close to them.
Here's what the dyno runs showed (70 degree day, low humidity). Took the engine to 5500 rpm.
Peak RWHP 186.2 @ 4350rpm, max torque of 269.2 @ 2750rpm. HP and torque falling off after the rpms noted. Engine sounded strong all the way to 5500rpm, so I don't think there was an ignition problem.
Given the relatively low rpms where power and torque peaked, and the low RWHP, I'm suspecting the cam is not an L-79 clone.
Opinions solicited.
Thanks, Ralph
A decent L-79 should make about 220 SAE corrected RWHP and a 327/300 about 190. So your engine's performance is closer to a 327/300 than an L-79.
You need to specify the dyno type and what, if any, correction method was used. If you have a graph scan and post it.
Once way to estimate the installed cam is to know manifold vacuum at observed idle speed. These are well know for OE engines.
So...?
Duke
So...?
Duke
How smooth is the idle? Any lumpiness to it at all? Vacuum at idle? What rear gears are in it and what size tires are you running? Knowing that would narrow it down.
If the current compression ratio is truly 10.1 versus 10.5, whether a 300 HP or L-79 cam the average difference in torque/power across the rev range would be on the order to 2-3 percent.
Idle behavior is always a good clue to the cam's characteristics.
Duke
"I" would think that in identical vehicles with only a difference in tires/rer that one with a 4.56 and short tires should be significantly difference from one with a 3.08 and tall tires.
Bill
I'll be checking vacuum today or tomorrow. Rear gears are 3.36, tires are 215 70 R15.
Thanks, Ralph
Thanks, Ralph
Flat top pistons....on dyno 380 torque 345 HP just the engine dyno
5,300 rpm with crapy distrubtor at the time with scatter ...
Jack
Compare chassis dynoruns to a well built 327 for street use:
Duke
Other variables would probably be differential gear ratio, assuming that dyno pulls are always done at 1:1 trans ratio. Check Test C here (a 3.70:1 diff should translate to higher power loss percentages and higher trans input shaft speed would do the same:
http://www.hotrod.com/articles/ccrp-...in-power-loss/
K&N 14"x4" air filter, Corvette drop base and lid
Holley 600 dp, choke horn milled and blended, Primary - 69, Secondary – 74, Squirters - 21
1/2" Aluminum open spacer port matched to manifold, exterior polished
Edelbrock Performer RPM intake manifold, port matched, exterior polished with all extraneous castings and lettering removed
Homemade lifter valley splash shield to keep hot oil off manifold bottom
Manifold heat riser crossover blocked
Camel hump 1.94/1.50 heads hogged out to 2.02/1.60, pocket ported, port matched, pump-friendly hardened seats, 3-angle valve job
All porting and port matching performed by Juan Mendoza of Flow Technology
Cylinder bores clearanced to unshroud the valves
Comp Cams 1.52:1 roller-tip rockers
Crane Cam Vintage Muscle 327/350 hp cam, 222 degrees @ 0.05, 0.447" lift (with 1.50 rockers)
Doug Thorley headers, dechromed and ceramic-coated
2.5" mandral-bent exhaust (including tips), 2" cross-over just before rear axle
DynoMax stainless Ultra Flow mufflers
Millerspeed 1-1/2” Gilmer under drive belt drive system
Mallory Hyfire IV CD ignition box triggered off Accel points
Mallory high voltage chrome coil
Mallory spiral-wound coil wire
Mallory solid copper plug wires, ends soldered to wires
Champion plugs
37 degrees total ignition advance
Carter high volume fuel pump
Melling high volume oil pump
Open breathers
Polished aluminum high flow water pump
160-degree thermostat
Flex fan with polished aluminum spacer
Polished aluminum one-wire 100 amp alternator
Header Power Bracket
Keisler TKO600 5-Speed
Hurst shifter
3.70:1 positraction with Big Block yokes
225/60/15 Firestone Firehawk SZ50s on 7”-wide Western 30-spoke Turbine Wheels
Actually the hp is down a bit because the valve springs had gone over 30# weak. They have now been replaced and the engine pulls better but has not been on the dyno again since.
.. depends on your perspective
... the usual 'rule of thumb'
