Tighter steering ratio, tighter on center steering rack for C5/C6?
#41
i own a 09, and the new rack is not any better. still very little feel and feedback.
now ive never driven a pre 09, so maybe they somehow are worse.
i also have aftermarket race wheel.
i came from a 00 SS fbody where i felt very one with the car i could feel and sense everything the car was doing. when i swaped to the vette i felt like i was driving a simulator. totally disconnected from the car.
im obviously refering to feel here, not ratios.
42707rfz (10-08-2022)
#42
Supporting Vendor
Received 2,316 Likes
Interesting you bring up an 09...my gf's car is an 09, so that's what I drive back to back, to my car...lol. She had an E46 330ci ZHP prior and I had the S2k, in addition to my Z06. The 09 steering is certainly different than the C5...that's how bad the stock c5 is. When she bought it I noticed an immediate difference/improvement over mine...this immediately compelled me forward and that's when I did the steering wheel. I wouldn't call the 09-13 ideal, but it's certainly better. On center is better, but I agree on feel...though I do think it has better feel than the C5 at lower speed. A very high level and accomplished gentleman driver I rode with in 2012 (he's the partner of a WELL known race track) had a ZR1 and commented then that he only drove the ZR1 with one hand, to actually feel what the car was doing. We did some laps and he indeed drove with pretty much nothing but his left thumb...lol...talk about smooth and fast. By his perception, that's how numb it was. I've heard Jan Magnussen comment the same and also drove the C6 one handed.
I've yet to drive a C7, but Tadge spoke extensively about the C7 having 500% increase in steering system stiffness, which they felt finally brought the C7 on par. I have repeatedly looked at Grand Sport...I just love this damn C5Z and I own it. I don't want a payment at this time.
#43
Hi all! Has anyone tried something like this for faster steering in their corvettes? https://slrspeed.com/products/corvet...teer-angle-kit
I have a 2007 z06 that i use on street and trackdays and i feel that the steering ratio is a little too slow. This kit is mostly for drifting i suppose and I'm not after the extreme steering angle but it should speed up the steering a lot. Im just curious if anyone has tried something like this for a street/track car?
#44
Supporting Vendor
I've gone down to a smaller diameter steering wheel and solid ends...made a big different for sure. Getting a more aggressive alignment and the square setup also really increase the front end feel and response. I think the drift kits have too much angle built in to them, is my worry.
#45
I will start about the same as you and if I'm not happy with that maybe i will try this one. I'm running 295s in the front and i'm rubbing a bit when at full lock. So more angle is not an option. Maybe mount like a mechanical stop so you can't turn more than factory?
#46
Supporting Vendor
Well, limiting the angle would address the one issue, but drift angle really isn't stable for a street/road race type of build. Even with caster built in, they can be really twitchy on center and frankly, plus the system loses leverage so it can make the car follow grooves and surface undulations much worse. It'd be one thing if that company made something that pulled the tie rod connection in slightly, but...that's a lot. I think stiffening the steering, going with a smaller diameter steering wheel (big difference) and even going with the Doug Rippie rack bushing are all things that will help a lot.
#47
Any news regarding steering racks?
I now think that upgrading to newer part simply won't work on 2008 car. Mechanically everything fits, but electronics will be mad. Unless there's someone's experience in upgrade, I'm going to order remanufactured part of same year for my '08.
Also, what bushings do people recommend? DRM: Aluminum or Delrin?
KnightDriveTV (05-03-2019)
#49
Supporting Vendor
dowroa (05-05-2019)
#50
#52
My C5z and c6z will both throw the passenger out the window if they are not belted in. Stock racks.
#53
Supporting Vendor
Your opinion of the steering will always be relative to what you've owned and driven prior, that's all I can tell you. I think the word "fine" is appropriate for the Corvette steering...it is indeed...fine. What it isn't is, great...not even close...it's just simply, fine. Putting someone through the window, due to lateral capability has nothing to do with steering precision, on center precision and feel. I can yank the wheel of a school bus and throw people around.
#54
Your school bus must generate awesome grip.
mikeCsix (06-18-2022)
#55
Supporting Vendor
I've owned BMW's and instructed/driven Porsche. Best was a GT3. My point to the original poster and the "reviver" is that changing the rack ONLY is not going to do much. He can probably get 99% of what he wants with making sure ALL parts are up to spec, then getting tires with stiffer than oem sidewalls (not run flats) and setting front toe to his liking.
As a matter of fact, I did own a school bus for a bit...lol. Indeed though, in 3rd grade our school bus driver was drunk and would fling us around quite a bit. Is was a fun first couple months until he was fired...lots of injuries on the bus...lol. He was a fun guy actually, he would try to jump railroad tracks and all of us in back would fly in the air. Oh the good ol 80's.
Been catching a couple of your smart string/camber vids btw...helpful to see how you attach to these cars, etc.
#56
Thanks, everything I post & all the videos on my channel have one objective, just helping out with what I learn by doing myself. Of course there will always be different opinions on just about everything. Mine is just one.
KnightDriveTV (05-16-2019)
#57
Supporting Vendor
Figured I'd add a square setup to my channel's list. I only started my channel a couple months ago, but I strive for good production quality and some cinematic flavor...that's my angle. It's the old wedding videography guy in me I guess. I love film making, so I'm really going to push some limits on my channel to make some epic sh*t if I can. For growth though, good quality info videos like Froggy makes are gold as well...
froggy47 (05-22-2019)
#59
Im going from a c5 rack to a C6 rack from a 11 Zr1. Ive popped countless racks running 335 slicks, etc. I also have a T1 pump in my car. It is currently at T1 getting upgraded from 1200 PSI to 1800 PSI due to the load/strain from the demands.
#60
My Rack has developed a slight leak. I'm considering the same. Whats involved in the swap?
