C5 Dry Sump install
Nice pics! Sweet looking pump too
Similar to your pics, I went solid diff on the passenger side (which I may have to monitor for NVH looseness).
I differed from your pics by having a 3 gallon tank set off in my trunk. Which necessitated having the lines hug between engine block and headers, and strap to the torque tube. PITA really. At the point in time where I installed, I had only seen the tanks put in passenger seat location or in the trunk; and I wanted hot oil as far away from me as possible lol.
You trim any of the front subframe assy for install so the lines could clear? What pump model are you running?
Former Vendor
Randy
Former Vendor
A tick of subframe work was needed.
I will check for a part number in the AM. I just got home
Randy
Shortly thereafter yes, the pump on this system pulls all of the oil out of the engine and returns it to the oil tank which in turn gravity feeds the oil pump which is still internal to the motor. So what would happen is that the engine will fill up with oil first and then run out of oil for the pump to feed the bearings.
This whole get-up looks very similiar to mine, engine mounts, KS location and all.....my tank is different and slightly different location , but.....
Former Vendor
Randy
You could even wire up an RPM meter and hook it up to your data aq to flash a light if it goes below a certain RPM.
Its the first part I'm trying to understand.. why would the windshield get covered in oil if the pump stops due to a broken belt?
John
I haven't ever monitored this, but I wander if there is a measurable pressure from the dry sump pump back to the tank that a low pressure hob switch would be able to monitor. If there is the solution to this would be quite simple with an idiot light.
I know that I would feel alot better knowing that the belt fell off/broke before it emptied my tank and possibly sprayed oil all over the windshield.
Additionally on this I was not a big fan of what ARE's only pulley retension methods were, so my pulley got some nylon washers and a bolt and washer on the end of the pump shaft to make sure that the pulley does not wander causing the belt to be launched...I haven't thrown a belt yet.....and dont want to. But if I did I would want to know early as my motor is no $3500 LS6...
St. Jude Donor '06
Former Vendor
Randy, I can understand the second point you made about not using a the sump pump for the pressure side... (belt breaks, no oil pressure, bye-bye engine). The crank driven pump eliminates that issue.
As a new dry sump user (LS2 in an M3), I've been trying to figure out a clever way to do this and I'm surprised no one has an off the shelf solution for dry sump owners. Any one know of one?
John
John
Randy
[QUOTE=Wasserott;1576564921]
Would you happen to have the part number of that sump tank?
What is the capacity?
I have a stock LS7 pan with a baffle installed, so I will just have 2 lines, plus the large DRM oil cooler, which will be plumbed into the stock oil filter location.
Where can I get custom lines made?
Thanks for any help I can get.
