Convertible Roll bar??? Any suggestions?
Old Jan 2, 2012 | 12:48 PM
1LOMARO's Avatar
1LOMARO
Default Convertible Roll bar??? Any suggestions?
Wife got her 94 Vert for Xmas, and now is wanting some form of bar that is structural. I've searched and I'm having no luck finding anything. Thanks for help in advance.
Old Jan 7, 2012 | 12:48 PM
1LOMARO's Avatar
1LOMARO
Well I guess its up to me to design and make something.... I keep telling the wife that it will be nothing more than a headache rack, but she is not letting the idea die...
Old Jan 7, 2012 | 12:59 PM
c4cruiser's Avatar
c4cruiser
Is there a particular purpose for a roll bar??
Old Jan 7, 2012 | 01:00 PM
Jon Hekking's Avatar
Jon Hekking
If that's how she feels she should have bought a coupe and taken the top off. I have NEVER seen any C4 vert with a roll bar or support that didn't look ridiculous.
Old Jan 7, 2012 | 01:13 PM
Vette Daddy's Avatar
Vette Daddy
If Mama aint happy............................
Old Jan 7, 2012 | 01:35 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Heres a custom shop in NorCal
Old Jan 7, 2012 | 02:59 PM
pologreen1's Avatar
pologreen1
Mitch piper
his car 6 pt MITCH PIPER ROLLBAR
Another
Note the cutouts in the deck lid, and also the scrape marks on the side of the rollbar from raising and lowering the convertible top:
..and a cross-brace for strength and a racing harness :-)
Here's how it attaches behind the seats
BTW the GM AUX hardtop has a bar in it i f it helps. THere are also cheapo hoops to put in now also that are more for looks behind each seat.
Old Jan 7, 2012 | 08:00 PM
1LOMARO's Avatar
1LOMARO
Not to me unless the power levels are high enough to support them or the car is being autocrossed. This is her first car with this type of power level and she just said she would feel more comfortable if there were a bar. As Vette Daddy said.. if mama ain't happy...
Old Jan 8, 2012 | 11:22 PM
helphos's Avatar
helphos
Here's mine. It's from Autopower. Fits under the Convertible top nicely.
It was on the car when I bought it, so I can't give any details of installation.
It does make it a little harder to get into the storage area, though.
good lluck
Old Jan 9, 2012 | 11:09 AM
c4cruiser's Avatar
c4cruiser
What I would suggest is that you look for a factory convertible hardtop. When this top is properly installed (using the heavy steel attaching brackets at the B pillars), the 'vert with the hardtop is actually stiffer than a coupe The top is easy to install (maybe 5-10 minutes with two people and still gives you the convertible for sunny days.
The factory hardtop has a large "halo" bar built into it that is similar to the one in the coupe. That provides the strength and stiffness that takes away the cowl shake and for street use, makes the car a lot quieter inside. It will also provide rollover protection.
Depending on the class she runs in, consider a "Camber Brace" to further stiffen the front of the car. This brace ties the upper part of the frame together at the upper control arms. Then a good alignment. Vette Brakes has some good alignment setting on their website. Look at the "Advanced Street" values to start and changes can be made from there.
Old Jan 9, 2012 | 07:28 PM
boltvette's Avatar
boltvette
Angelwings Tech makes a bolt-in that is easy to install, doesn't interfere with the top operation, and really looks good, too. And it's approved for HPDE and track day use at several tracks across the country, so if she gets the urge to see just what her Vette can do, she is set.
Old Jan 11, 2012 | 12:15 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Either go with the autopower rollbar and do the fabrication work.
Or find someone that will build you a bar to your specs and do all the fabrication work.
Lots of places will build you one. Had Genesis One in GA build me one that is a work of art in my coupe. tightened it up considerably.
Old Jan 13, 2012 | 01:57 PM
Biker's Avatar
Biker
I searched high and low to find a roll bar for my '86 vert. I would up buying a set of chrome hoop bars from a CF member. They came with his car and he didn't want them anymore. Before I found the hoops I almost bought a roll bar for a Miata. The dimensions were close enough that all it needed was minor mods to fit.
Old Jun 2, 2026 | 04:10 PM
AmILegal's Avatar
AmILegal
1st Gear
Here is my story. In the fast lane going 80ish when the car in the lane next to me comes into my lane pushing me over to the center shoulder As I look ahead there is the concrete pillar for the overpass right in front of me. Yanked the wheel hard back into the fast lane. It was either that or be a mess on the pillar. Hit the car next to me putting me into a slide heading back towards the center divider. Hit the center divider hard probably 70ish (the white concrete barrier that is tapered wider at the bottom then smaller towards the top) the car went airborn and landed facing the other direction and spun along the center divider then across all lames and came to a stop facing the wrong way against the slow lane wall. Even through all that I didnt feel like the car was going to flip over. The car was shaped like a boomerang from the impact to the center divider. Doors wouldnt open. Climbed out of the targa top and hopped down on the freeway. Only injury was bruises down my arms and legs from the sideways impacts against the door and console. I can say for certain that car wont flip on you. If anything would have flipped a car that was it. Don't worry about a cage. These cars are solid as can be..
Old Today | 04:05 PM
ThickLizzyVetteswerv's Avatar
Solid as can be for a 40 year old design that was compromised by upper management right off the drafting table and marginal at best when new...
There's a wrecking yard in my area with lots of C4s and they have some examples that are chilling to look at. Windshield crushed down flush to the tops of the doors. Hardtop roll hoop crushed down flush to the dash. They do turn over and when they do, you go ahead and you die.
The roll bar is a sensible desire on the surface but unless it's really done right, your wife should wear a crash helmet every time she drives to avoid a fractured skull in the event she has a violent collision and that lap belt allows her to bounce up and impact her head on the bar.
To Convertible Roll bar??? Any suggestions?
