Old Mar 5, 2015, 06:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
Targa Top Creaking, Popping, Squeaking FIXED!!
Old Apr 5, 2013 | 10:47 PM
SeeFiveOhFun's Avatar
SeeFiveOhFun
Default Targa Top Creaking, Popping, Squeaking FIXED!!
First off, big thanks to forum member jdk541 for posting "It's Like Getting a Brand New Car for $3.03" last year. Based on that post, I fixed my horribly popping, squeaking, creaking targa top for . . . (drum roll) . . . 75 cents! My story - 2009 that had no issues - but I like to drag race - and after a couple trips to the strip, I started having the issues with the top making noise. At first, I thought my stereo was clipping - it really sounded like the speakers having issues. But the "popping" sound proved to be the targa top. Long story short, I went to Lowe's after work today, they didn't have the Danco brand O-rings in the aforementioned post, so I bought a slightly thicker O-ring. I immediately noticed more muscle needed to secure the front latches. The bottom line was going from brutal creaking and popping that even the stereo could not mask to DEAD SILENCE after spending $.075 tonight! I'm simply stoked. The info on this forum is fantastic!
Old Apr 5, 2013 | 11:36 PM
haberman13's Avatar
haberman13
Sweet, thanks for posting!
I'm going to do this tomorrow.
Old Apr 6, 2013 | 12:07 AM
Nyvetteguy007's Avatar
Nyvetteguy007
Did the same thing a while ago and works like a charm
Old Apr 6, 2013 | 12:54 AM
C6RaceCar's Avatar
C6RaceCar
I heat shrinked the pins on my top and that did the same thing. But yeah getting the top to sit in the gap tighter is the key. Congrats.
Old Apr 6, 2013 | 03:18 AM
Like dem Vettes's Avatar
Like dem Vettes
I put a layer of Super-Lube grease on the pins. It provided an improvement, but I will try the o-rings.
Old Apr 6, 2013 | 04:35 AM
26sonic's Avatar
26sonic
so 2 "o" rings to the front posts of the top?
Old Apr 6, 2013 | 07:31 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
If I understand your question, no, you are adding a second o-ring on each post.
I found Home Depot didn't have the Danco package but Lowes across the street did. That was the only stock number that seemed to be in demand. I wonder why?
Old Apr 6, 2013 | 07:33 AM
Nyvetteguy007
I did that too along with the O ring fix...never an issue since.
Old Apr 6, 2013 | 07:35 AM
arrie's Avatar
arrie
Simplify
From: forging ahead...making up for lost time and embracing each day thankful to be alive.... nj
St. Jude Donor '13-'14-'15
~~~ CFOT Book Folder ~~~
love the penguin.....
Old Apr 6, 2013 | 08:01 AM
RobLo's Avatar
RobLo
I just bought the "O" rings from Home Depot, 1/4" ID. I also bought the "E" clips from there, an earlier post had recommended 5/32" clips stocked by Lowes but they never seemed to have that size either (another "I wonder why", ), I read you could also use 3/16" clips and Home Depot had them so I bought them too. Will put them in soon, still kinda cold here in NY so my top hasn't been making a lot of noise....yet.
Old Apr 6, 2013 | 08:02 AM
cpmatthew's Avatar
cpmatthew
I added two O-rings to the front posts of my targa top last summer, but they have since worn out. I need to replace them with something a bit more durable. Are these brasscraft o-rings made of sturdy plastic or rubber?
Old Apr 6, 2013 | 08:30 AM
corrado's Avatar
corrado
Gonna try this. Done the E clips and they help but still some noise sometimes.
What section of Lowes are these O Rings? Pretty sure if I ask the typical teenage staff member for rubber O Rings they're not gonna have a clue what I'm talking about.
Old Apr 6, 2013 | 10:24 AM
southpaw5000's Avatar
southpaw5000
I would look in the plumbing aisle where you find the brass water valves and misc. fittings.
Old Apr 6, 2013 | 11:20 AM
jdk541's Avatar
jdk541
St. Jude Donor '22-'23-'24
SeeFiveOhFun - Glad to hear I could help out. As an update, I think I did this $3.03 fix about 9 months ago. It is still holding strong. Nearly a sound from the top.
Old Apr 6, 2013 | 12:26 PM
SeeFiveOhFun
Good to hear (or not hear...lol) - thanks again for the info!!
Exactly - they're in plumbing.
They are rubber.
Simply add one more O-ring to each post
Lol - thanks for noticing! I saw the dog toy sitting there so thought I'd include it in the pic and see if anyone noticed
Old Apr 6, 2013 | 03:03 PM
corrado's Avatar
corrado
THANK YOU SIR!!
Old Apr 6, 2013 | 03:56 PM
HEB's Avatar
HEB
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
This worked on my 09 last year
To Targa Top Creaking, Popping, Squeaking FIXED!!
Old Apr 6, 2013 | 05:15 PM
Mike Campbell's Avatar
Mike Campbell
Looked for "O" rings at Lowes, Home Depot, Advanced Auto and Autozone. No luck. I'll have to try Ace Hardware next. They had everything but the 1/2" OD x 1/4" ID. But I'm gonna keep looking! Thanks for the tip.
Old Apr 6, 2013 | 06:33 PM
arrie's Avatar
arrie
Simplify
This was purchased today at lowes. The part number is #78 and is found in the plumbing aisle.
Old Apr 6, 2013 | 06:42 PM
1BADLS3's Avatar
1BADLS3
www.mcmaster.com
Search for part number: 9452K171
$2.12 for pkg/100. that should last awhile.
