Removing Frisbee
Old Aug 19, 2014 | 04:13 PM
C4ProjectCar's Avatar
C4ProjectCar
Default Removing Frisbee
I'm thinking about removing the "frisbee" from the water pump, but I have a couple of questions.
        Thanks in advance.
        Old Aug 19, 2014 | 04:23 PM
        Joe C's Avatar
        Joe C
        Originally Posted by C4ProjectCar
        I'm thinking about removing the "frisbee" from the water pump, but...
              Thanks in advance.
              I'd be surprised if you gained anything - personally, I think performance gains from removing the "frisbee" is pretty much an urban myth. if you gain one HP, I'd be surprised. i can't say removing it will or will not cause any negative side effects. my understanding is only automatics had the frisbees anyway. I've had two 90's, and as tempting as it was, I just left mine in place. if something DOES go wrong, like anything with a corvette, it will probably cost some bucks to fix. but hey, it's your corvette - your pretty much free to do anything you like. I wouldn't expect much by removing it.
              Old Aug 19, 2014 | 04:26 PM
              C4ProjectCar
              Originally Posted by Joe C
              I'd be surprised if you gained anything - personally, I think performance gains from removing the "frisbee" is pretty much an urban myth. can't say removing it will or will not cause any negative side effects. my understanding is only automatics had the frisbees anyway. I've had two 90's, and as tempting as it was, I just left mine in place. if something DOES go wrong, like anything with a corvette, it will probably cost some bucks to fix. but hey, it's your corvette - your pretty much free to do anything you like.
              Thanks. That confirms what I've been finding seems to be the consensus.
              Well... there's a metal disk with four bolts on it in front of the water pump pulley. That's the frisbee, right? Mine is a '90 with the ZF6.
              Old Aug 19, 2014 | 04:53 PM
              Joe C's Avatar
              Joe C
              well, I guess I'm wrong here. somehow, I thought they were only on automatics. oh well, guess you learn something new everyday!
              Old Aug 19, 2014 | 06:40 PM
              WW7's Avatar
              WW7
              If you do remove it, don't forget you have to take up the 1/4" space left by the frizbee with washers..3 or 4 on each bolt is what I used.....Mine had bolts sticking through from the back and I had to put nuts on the front..I have also seen ones that the bolts went in from the front screwing into the water pump disk .......WW
              Old Aug 19, 2014 | 06:50 PM
              Dagge's Avatar
              Dagge
                    Thanks in advance.
                    Remove it!
                    Theoretical power gain if you know your math but nothing you will notice.
                    It looks better without it.
                    It's easier to install the multi rib belt.
                    If you have an automatic and hear a chirping sound when shifting gears when you floor it then that sound will be gone afterwards.
                    No side effects. Disc was deleted shortly after. GM thought it helped to keep momentum when the ac kicked in but didn't do much.
                    Don't forget washer same thickness as the disc.
                    Old Aug 20, 2014 | 12:03 AM
                    C4ProjectCar
                    Originally Posted by Dagge
                    Remove it!
                    Just took physics so I follow the math. I agree that it looks better without (had to remove it to tighten the harmonic damper bolt on the crank). My main concern was side affects, but if there are none I'll just leave it off. Thanks!
                    Old Aug 20, 2014 | 03:18 AM
                    Shag's Avatar
                    Shag
                    Yep, I took mine off a few months back. Easier to see timing marks. Its somewhere in my backyard. My German Shepard keeps running off with it.
                    Old Aug 20, 2014 | 06:36 AM
                    WW7's Avatar
                    WW7
                    Contrary to what the posts above are saying, there is one documented possible side effect... On some cars there can be a jerking motion felt when the A/C compressor comes on..This was why the frizbee was installed on the cars in the first place... There have been some guys that have put the frizbee back on because this jerking motion was not something they could put up with..I did have a slight jerking motion when I removed mine, but not as bad as some have had and I decided to live with it....Just be forwarned that this can be one problem...WW
                    Old Aug 20, 2014 | 02:01 PM
                    GKK's Avatar
                    GKK
                    I removed the Frisbee on both my 89 and 91 Vettes and didn't have to add any washers to the four mounting bolts.
                    I just unscrewed the four bolts, removed the frisbee and reinstalled the four bolts checking the backside to make sure the bolt ends had clearance.
                    The earlier TPI Vettes needed to have the washers added.
                    No, problems or side effects of any kind noticed...
                    Old Aug 20, 2014 | 03:47 PM
                    C4ProjectCar
                    Originally Posted by WW7
                    Contrary to what the posts above are saying, there is one documented possible side effect... On some cars there can be a jerking motion felt when the compressor comes on..This was why the frizbee was installed on the cars in the first place... There have been some guys that have put the frizbee back on because this jerking motion was not something they could put up with..I did have a slight jerking motion when I removed mine, but not as bad as some have had and I decided to live with it....Just be forwarned that this can be one problem...WW
                    Okay, thanks WW7. I'll watch out for that and if it happens putting the frisbee back on is an easy enough fix.
                    Old Aug 20, 2014 | 04:13 PM
                    Sleazy Rider's Avatar
                    Sleazy Rider
                    Veteran: Marine Corps
                    The last time i saw that frisbee on my 89' zf6, it was doing just that...skipping down the driveway never to be seen again. And that was before my 20 year old son was born and have not noticed any side effect with it gone except that its easier to get to the water pump. Just used bolts that are 1/4" shorter.
                    Old Aug 20, 2014 | 04:21 PM
                    Race Prepared's Avatar
                    Race Prepared
                    GM spent $$$$$$$$$$ to install it for a reason, I'd leave it alone!
                    Old Aug 20, 2014 | 05:20 PM
                    WW7's Avatar
                    WW7
                    No, problems or side effects of any kind noticed....
                    They must of used both kinds on the 89, because on mine I had 4 bolt studs sticking out through the pulley and I had to use washers with the nuts on the front...Without the washers the pulley is loose.....Maybe they just used whatever they had lying around at the time to build 89 cars.........
                    Like I mentioned above, the reason was because on some cars when the A/C compressor kicked on it could be felt as a "jerk" which alot of people didn't like...If you do a search you will find a ton of threads about this happening..Some just live with it or don't really notice it....WW
                    Old Aug 20, 2014 | 06:07 PM
                    MavsAK's Avatar
                    MavsAK
                    Frisbee's been off for a year and a half.
                    8k miles on the car since.
                    No ill effects.
                    Definitely enjoy the cleaned up engine bay.
                    Old Aug 20, 2014 | 06:15 PM
                    Dagge's Avatar
                    Dagge
                    They did and they was wrong. Happened before and will happen again.
                    Old Aug 23, 2014 | 07:40 AM
                    HlhnEast's Avatar
                    HlhnEast
                    This is what I have gathered as well. It had something to do with the jerking motion occasionally throwing a belt. The frisbee was kind of a counterweight to keep the action of the a/c compressor engaging smoother.
                    To Removing Frisbee
                    Old Aug 23, 2014 | 02:11 PM
                    C4ProjectCar
                    Thanks, I'll keep that in mind.
                    Old Aug 23, 2014 | 09:23 PM
                    HAD2HAV2's Avatar
                    HAD2HAV2
                    I removed my 88 Frisbee in 2009. No problem. I didn’t know what it was for. Most everyone here on the Forum said take it off. One less part to remove when your water pump starts to leak.
                    Old Aug 24, 2014 | 04:35 AM
                    65Z01's Avatar
                    65Z01
                    Cruise-In II Veteran
                    Per Gordon Killebrew at Carlisle in 2000: "During testing of the new A/C compressor on the '88 Vette GM noticed an occasional "squeal" when the compressor engaged so they added the "frisbee" to dampen out sudden pull on the serp." "Removing the "frisbee" will release ~10chp from parasitic drag".
                    I have verified the 10chp gain by trap speed increase of 1mph, corrected for DA.
                    In 2000 I immediately removed the "frisbee" from my prior '88 and three years ago removed it from this '88 and never had even a squeal from the belt.
                    The '88 & '89 "frisbee" is a uniform thickness 10lb disk so thick lock washers are advised under the bolt heads. The '90 & '91 units are much thinner with mass concentrated in the outer rim so washers may not be needed.
