Removing Frisbee
Old Aug 24, 2014 | 07:07 PM
C4ProjectCar's Avatar
C4ProjectCar
Originally Posted by HAD2HAV2
I removed my 88 Frisbee in 2009. No problem. I didn’t know what it was for. Most everyone here on the Forum said take it off. One less part to remove when your water pump starts to leak.
Originally Posted by 65Z01
Per Gordon Killebrew at Carlisle in 2000: "During testing of the new A/C compressor on the '88 Vette GM noticed an occasional "squeal" when the compressor engaged so they added the "frisbee" to dampen out sudden pull on the serp." "Removing the "frisbee" will release ~10chp from parasitic drag".
I have verified the 10chp gain by trap speed increase of 1mph, corrected for DA.
In 2000 I immediately removed the "frisbee" from my prior '88 and three years ago removed it from this '88 and never had even a squeal from the belt.
The '88 & '89 "frisbee" is a uniform thickness 10lb disk so thick lock washers are advised under the bolt heads. The '90 & '91 units are much thinner with mass concentrated in the outer rim so washers may not be needed.
Thanks for the info.
10 CHP seems like a lot for such a light disk...
Old Aug 25, 2014 | 02:45 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Apparently GM re-engineered it from the 10lb boat anchor of the '88 & '89 to the lighter version for '90. Rest assured though that the rotary inertia of both designes is the same as this is what stabilizes the system when the A/C compressor kicks on/off.
And it is this rotary inertia that sucks up the 10chp that came from the new (in '88) D-port heads.
Old Aug 26, 2014 | 07:01 AM
C4in mesa's Avatar
C4in mesa
I removed mine when the engine was being rebuilt and was stripped to the bare block. Zero issues. As far as it being a benefit goes, taking a 10lb steel plate off the water pump pulley is a no brainer. I can remember all of us LAUGHING at this metal plate when we were passing it around.
Old Aug 26, 2014 | 09:39 AM
TA's Avatar
TA
I've had mine off my 91 since 2001 or so with no ill effects. I have no ideas of power gains, if any, although being a 91 I had the smaller, lighter disc.
Old Aug 26, 2014 | 10:21 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I removed that weight 13 years ago, with noticing no difference in HP or belt squeal.
There was the reason but my car at no concerns.
Old Feb 24, 2025 | 11:40 PM
Thomas Tara's Avatar
Thomas Tara
2nd Gear
Default Issues with removing the frisbee??
I read up that not having the Fresbee, the water pump pulley may not have the damping effect that was intended to smooth out those load changes from the A/C compressor cycling. This could cause more vibration to be passed through the drivetrain and into the cabin.
I feel a lot of vibrations in my shift ****, but only when I turn my AC on and go above 3k RPMs.
Could this be my problem?
