spare tire for my 81
Old Mar 15, 2016 | 04:47 PM
brews62's Avatar
brews62
Default spare tire for my 81
where is the best place to get a spare tire for my 81? I pulled mine down and it is dry rotted, .. please let me know ,, thanks .. Bruce
Old Mar 15, 2016 | 05:08 PM
BKarol's Avatar
BKarol
If what you pulled out is a 195/80/15 on a space saver rim (15x5 not a regular rim) then you just need to chose what 205/75/15 tire you like and have it mounted on the space saver rim. No one sells the 195/80/15.
Old Mar 15, 2016 | 05:27 PM
brews62's Avatar
brews62
yes mine is the original 195/80 d15 , so the 205/75/15 will fit okay under the car with no problem correct??
Old Mar 15, 2016 | 06:00 PM
BKarol's Avatar
BKarol
This is the original spare on my 78 :
The 205 on the space saver:
Old Mar 15, 2016 | 06:13 PM
gbvette62's Avatar
gbvette62
Yes, a P205/75R15 will fit easily into your spare tire tub. Dimension wise, is about as close as you will find to the original 195/80D15.
If your car has the standard P225/70R15 tires on it, you could put a 225/70, on a stock 15x8 rally rim, in the tub also. The 81 tub is the same as tubs used in earlier years, so the P225/70R15 will fit without any issues.
Even the optional P255/60R15 with fit in the tub, but it will require the tub to hang lower, increasing the likely hood that it will drag over bumps, driveways etc.
Old Mar 16, 2016 | 05:55 AM
brews62's Avatar
brews62
thanks for your help.. i am gonna go for the 225/70 ,bruce
Old Yesterday | 05:02 PM
Rusty 1981's Avatar
Rusty 1981
6th Gear
Default Cheap eBay wheel?
Would this $70 eBay wheel work for a 1981 spare?
" SIZE: 15x4. STYLE: 55 Rally. BOLT PATTERN: 5x120.7 (5x4.75"). FINISH: Dark Silver. WHEEL SPECS New Page 1. BACKSPACING: 2.5". "
I know this is an old thread but search engine pulls it up consistently.
Old Yesterday | 08:41 PM
MelWff's Avatar
MelWff
Have no way of knowing if that will clear the brake caliper.
Old Yesterday | 10:48 PM
Bikespace's Avatar
Bikespace
I keep mine in my wallet.
To spare tire for my 81
