Part two my hid
Part two my hid
Ok think I just learned to link my video. This is not the instructions but and overview of it. I will post instructions and parts needed if anyone is interested.
https://drive.google.com/open?id=0B8...Hd0NDNGMDltcVE
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Link to instructions. Wish it clearer but had to cut down size of file
https://drive.google.com/open?id=0B8...0l5Q2NhcmhaUFU
Hmmm, ...increasing the assembly pivot contact areas, anchoring the control arm pivot pin and motor shaft bushings for support.
I love simple, very nice Gary!
Your lower opening stop plates are inbound. (via USPS)
Good Luck and keep us updated with your intended mod...
mtndv8 (09-10-2016)
Received 19,305 Likes
'20-'21-'22-'23-'24
...remember, you are only limited by the space available, money available and your imagination, however mostly just your imagination.
For instance;
-Bi-Xenon projectors will fit into the C5 assembly. Often quoted "expert" opinions not withstanding...
What I'm currently working on in my shop;
-Retro-fitting Mercedes-Benz GLE "adaptive" LED headlights into the limited space of the C5 headlight bucket and still being "adaptive"...
Have fun with it Gary...
Very nice of you to say Gary, thanks much.
For instance;
For instance;
I had the same problem back in 2010.
I replaced the OEM rod with a metric SS M8-1.25 bolt that was a bit longer than the OEM rod. Then I secured it with a Nylock nut. This made the connection a bit tighter and will eliminate the retainer that holds the OEM rod in place from coming off in use.......has happened to me twice But there was still room for improvement, so I added one 5/16" nylon washer between the lifting arm and the headlamp assembly to further firm up this connection (see pic 2 sorry for the blur).
Jim
https://www.corvetteforum.com/forums...id-jiggle.html
Jim
