C5 Corvettes for Sale Classifieds: Used C5 Corvettes for sale as well as modified or stock Corvettes
The best of street/strip - 2001 lpe tt z06...
Old 01-14-2017, 05:03 PM
trayack
trayack's Avatar
Default THE BEST of street/strip - 2001 LPE TT Z06...
I’m honestly going to try and keep this as short as I can, but at this point a novel length post is the only thing what would do this car justice…
First, I guess I’ll start with a bit of the car’s history. The car is an original Lingenfelter car, and in the LPE world is known as “Greg’s Car” after the original owner. The car was originally built with a 417ci and a 6spd along with the LPE Stage 2 turbo system. The first owner had the car up here in the north east for roughly 6 years and it became very well known. The car has always been a drive it to the track, run the number, and drive it home type of race car. After a while the car was sold to “Chad” down in MS where it also stayed for roughly 6 years. During that time Chad made numerous changes to the car including the currently engine as well as swapping the trans out for a 4L80e conversion. Chad primarily used the car for grudge racing at Gulfport MS. After a while, the car again garnered quite the reputation and it got to the point where no one would race it and its money making ability stopped. It was at that point that I became the third owner. When I bought the car it had 14,600 miles on the chassis.
Over the past 3 years of ownership I’ve done quite a bit to the car with one goal in mind…completing Hot Rod Magazine’s Drag Week. I wanted a car that could run bottom 9’s on pump gas, get off the track then make a 7 hour drive…without touching it, ever. This year, I was finally able to realize that goal. My 5 day average with the car was a 9.33 at 149mph. Again, this is on pump gas, without make any changes to the tune…ever. Literally the only changes made between street/race were changing to the drag pack wheels and putting in the swing out door bars. I babied the car off the line at each track so the 60ft times were a lazy 1.48 leaving around 2000rpm off the foot brake. The best ET for drag week was 9.29 (x2) and the best MPH was 151mph. In its “race” trim the car weighs 3450lbs without me.
You simply will not find a more consistent, well mannered, well sorted car on this site…let alone one that will run 9.29’s all over the country on 93 pump. In the past year the car has been featured prominently on companies’/automotive sites and as a full feature in the November issue of Vette Magazine.
Below you’ll find a breakdown on what’s currently in the car. You’ll see that no expense has been spared, and frankly…there’s a disgusting amount of money in it.
CHASSIS
2001 Corvette Z06, Quicksilver. (17,000 miles)
LPE Mini-Tub Kit
DMC Racing 8.50 cert Chromoly Cage w/swing out door bars and custom window net. Carbon fiber tube protectors as well as carbon fiber chute handle. I challenge you to find a nicer fitting 8.50 cage in a full interior’d vette.
DMC Racing interchangeable parachute mount and trailer ball. DJ’s Safety Parachute, and custom DJ's window net
Rear of trans tunnel enlarged for 4L80e swap
Sparco Pro 2000 Driver and Passenger seat, both with G-Force Racing 5pt Harnesses
Entire interior coated in DynaMat Extreme
Still retains full heat/AC
EGT and AEM Fail Safe AFR/Boost Gauges on the A-pillar
Pioneer Flip out HU/Alpine DPX 4 Channel Amp/Pioneer 6.75 separate’s in the doors.
MOTOR-
434ci – (Under 4000 miles)
ERL Superdeck 1 block with the 6 head bolt option built 03/12
Callies Dragon Slayer Crank / Wiseco Billet Steal Rods/ Wiseco Pistons 9.5:1, Bearings coated.
GM LSX Heads / GM LS9 Cam / 1.7 ratio rockers / LS7 Intake
C6 Oil Pump / C6 Oil Pan / LPE Catch can
Stock coils / Iridium Plugs / Firecore50 plug wires
GM water pump, LPE Aluminum Radiator/w AN lines and fittings
FORCED INDUCTION / EXHAUST
LPE Stage 2 Turbo Kit
Garrett GT30 Turbos (60mm) – Low mount, not visible from engine bay.
LPE twin A/A intercoolers and LPE intake/compressor piping. Filter location is different than most LPE cars for increased flow.
DMC Racing custom 3 inch stainless exhaust – v-band’d and completely modular.
DMC Racing muffler delete pipes exit in factory location
Borla custom one off Titanium mufflers (car is almost stock quiet with these installed)
Alky Control Methanol injection (twin nozzle) – New pump in 2016, uses washer tank for meth
TUNING
Tuned by Don at SlowHawk Performance in Bridgewater MA. As stated above it runs on 93 pump gas and is currently running 16psi of boost on the street and the track. Current tune is good until 18psi. Car currently runs the stock C5 computer.
FUEL SYSTEM
Stock C5 tanks so the pumps are located in the lower driver’s side tank and easily accessible.
Lonnies Performance duel internal pump setup with brand new Aeromotive 340’s.
Lonnies Performance fuel pump wiring. 2nd pump turns on at 2psi of boost via a Hobbs switch.
Fuel Lab external filter
8AN feed line to an Aeromotive Pro Regulator, then into the stock fuel rails.
Fuel returns to the tank via the stock feed hardline.
All AN fuel lines coated in DEI Fire Sleeve
Fast 85lb injectors
DRIVETRAIN
Car has been converted to auto using a 4L80e. To accomplish this, the tunnel was enlarged at the rear bulkhead and the torque tub has been shortened. All interior pieces still fit as normal.
RPM Transmissions Level 5 4L80e with trans brake installed (never used) Just freshened.
http://www.rpmtransmissions.com/page77.html
Billet rail’d aluminum deep sump trans pan modified to accommodate the 3 inch exhaust
Pro Torque 3000rpm stall converter with electronic lockup
Quicktime SFI Bellhousing
B&M large trans cooler with fan mounted in front of the radiator.
All trans lines are coated in DEI Fire Sleeve front to rear
Stock GM Auto shifter in stock location
Trans is controlled by a TCI trans controller. Laptop will be included with the programing and current trans tune installed.
RPM Transmissions built C6Z rear end with 3.42 gearing.
Trans/Rear end braced using the ECS brace
DSS 2000hp axle upgrade
SUSPENSION
Stock C5 front cradle/arms/leaf spring/front sway bar removed
C6Z rear cradle/arms/leaf spring/ rear sway bar to accommodate the trans/rear swap. This swap moves the centerline of the wheel backwards 1 inch allowing the use of larger tires.
Penske adjustable remote reservoir shocks on all 4 corners. Shocks were completely rebuilt in 2016 and also have new bump stops installed.
Stock C5Z brakes front and rear. Calipers coated red.
WHEELS/TIRES
Street Setup
Front - CCW Classics 18x9 with Continental 265/35/18s
Rear – CCW Classics 18x13 (widened for mini-tub) Mickey Thompson ET Street Radial 345/35/18
Strip Setup
Front – Polished Weld Full Throttle 17x4.5 with new M&H Front Runners. This is the very first set of Full Throttle wheels sold to the public, in fact these are the actual wheels used in the initial advertisements. It took 5 months to get these
Rear – CCW 3pc Classics with a custom outer Ultra Lite beadlocks by Beadlock Conversions. 16x10, New Hoosier Drag Radials 295/50/16
BODY
As stated before, there is actually only 17,000 miles on the body/chassis. The car has lived in climate controlled garages and race shops for its entire life. There are a few blemish’s (paint chips ect.) but that’s to be expected from a car this age, and one that’s actually used as opposed to a show queen.
The rear brake cooling vents have been blocked off as a result of the LPE mini-tub kit.
A 5th Gen ZL1 Camaro hood vent has been added. The car will normally run in the 190-198 range all day long during the warm months and never has any cooling issues. The vent was added purely as a “just in case” mod for this year’s Drag Week. We often run for 7 hours plus worth of street driving in the middle of the country in 90+ degree temps so anything you can do to ensure the car stays happy is time well spent. As a side note, this single mod dropped the car’s highway cruising temp by a full 10 degrees.
OTHER
The car drives and handles like a stock corvette, though the adjustable Penske shocks make it even better.
With the stock ZR1 cam there’s no surge at idle or light throttle cruise. The trans is controlled electronically as is the lock up converter, so you simply put the car in DRIVE and go. The exhaust is very quiet, basically stock sounding so there’s no issues there either. The car looks very plain, but lots of time and money have gone into making it look and drive like just a normal corvette. If ever you could call any corvette a “sleeper” mine would be that car. Keep in mind that it also has the full vette suspension and brakes so it stops and turns just as well as it goes.
On the track the car is the easiest thing in the world to drive. Complete the burn out in 3rd gear, shift into DRIVE and stage. Apply the brake pressure and light throttle until the car starts to push through the brakes around 2300rpm. Once it starts to creep forward, simply let off the brakes and push your foot to the floor and hold on. The car goes LASER straight every single time. It doesn’t really start to get moving until just after 60ft but when it does it plants you in the seat. The trans shifts automatically at 5200rpm, so it’s really just a point and shoot driving experience.
When we race we run the same tune that’s in the car for the street. The ONLY changes I make to the car before a run are to change the wheels over to the drag setup and install the door bars into the cage. Literally ZERO other changes are made. Honestly, if you don’t 9.30’s in this car on your first time out, you’re doing something wrong. This car truly is THAT sorted….
Included with the car will be the trailer we use for Drag Week. This trailer has been used for all three of this car’s Drag Week appearances with zero issues. It holds the complete “drag pack” wheels and tires, two 5 gallon jerry cans of fuel and has an enclosed large tool box that will fit just about whatever you need for a week long drag racing event. With this trailer, the only thing we’ve had to actually put in the trunk of the car has been a small bag of clothes for one of us for the week. The trailer started out as a Harbor Freight 4x4 trailer but we’ve extended the tongue an additional 10 inches to help with tongue weight as well as backing up.
CLOSING
The ONLY reason I’m selling the car is to use the money for a down payment on a home. Hard to admit, but I guess everyone has to be an adult sometime, and my time has come. The car truly is everything I say it is and more. The hard part for me is once it’s gone; I know I’ll never own anything quite like it again. The car is well documented, with its performance at Drag Week and otherwise. I have any number of in car videos of the various runs and can also point you to the exact run times during the live Drag Week footage. I also have tons of pictures and also have a lift in my garage so if you want pictures of anything you don’t see, just ask and I’ll get them to you. To really appreciate this car you have to see it up close and in person, so I welcome you to make the trip. You won’t be disappointed. When I bought it, I drove to Mississippi (solo) and back to get it, and it was one of the best decisions I’ve ever made. Even if you don’t buy my car….I will say, don’t be afraid to travel for the RIGHT car. You’ll thank yourself later.
Since this post was originally created the motor has been out and fully freshened up and has less than 500 miles on it. While it was out the cam has been swapped to a BTR Stage 2 cam which gained a full 100whp at the same 16psi and at 19psi it increases to a 200whp gain, still on pump gas. This car should be very well into the 8's all day long anywhere in the country on the same street tune. The car is fresh right down to new brake pads/rotors and even tires. You're not going to find another one like it, let alone at this price.
ASKING PRICE - $45K (includes trailer/wheels/any and all bits and pieces)
- Travis (508)-221-0240
VARIOUS PICS
VIDEOS
trayack is offline
CorvetteBrent (07-11-2018)
Old 01-14-2017, 06:11 PM
IMXCITD
Support Corvetteforum!
IMXCITD's Avatar
GLWS!
IMXCITD is offline
Old 01-14-2017, 07:23 PM
n8dogg
n8dogg's Avatar
$60k as in sixty?
n8dogg is offline
Old 01-14-2017, 09:02 PM
trayack
trayack's Avatar
Originally Posted by n8dogg
$60k as in sixty?
YUP
- Travis
trayack is offline
Old 01-15-2017, 02:50 PM
Mike 92LX
Mike 92LX's Avatar
Nice car and glws!
Mike 92LX is offline
Old 01-16-2017, 09:47 PM
trayack
trayack's Avatar
I would also consider a cash+vehicle deal as long as the deal was heavy on the cash portion. Doesn't have to be a vette either.
- Travis
trayack is offline
Old 01-20-2017, 08:19 PM
trayack
trayack's Avatar
Here is the Super Chevy online article with some additional pictures for anyone that's interested.
http://www.superchevy.com/features/1...uns-drag-week/
- Travis
trayack is offline
Old 01-21-2017, 11:59 PM
edram454
edram454's Avatar
nice car. excellent performer.
edram454 is offline
Old 01-29-2017, 11:00 AM
Chokeu
Chokeu's Avatar
Car's a total beast, glws! Tuned by one of the best tuners in the US!
Chokeu is offline
Old 01-30-2017, 08:33 PM
trayack
trayack's Avatar
Thanks much. Seems the vast majority have zero idea what it takes to get a car to do what this one does. Don himself has said it would take close to $80K + the car to recreate this one at this moment.
I don't expect everyone to line up and drop this kind of money into a car but there will be someone out there who wants a 4L80 in one of these cars and at the moment there's only a handful in existence....and this is the ONLY one currently for sale, then add in the full cage in on top. If you've got those on your wish list, this is the only car for you.
On a side note, I love Don. He's a no nonsense guy. He won't fill you full of hopes and dreams just to make some cash. Hell, he's literally refused to do a few mods because they wont improve on things....and then called me an idiot for asking. THAT kind of guy gets my money (even if he doesn't want it) and my business.
- Travis
trayack is offline
Old 01-30-2017, 08:42 PM
Chris Stewart
Chris Stewart's Avatar
Aha! I said the same thing on Facebook. I'd keep it forever before giving in to lowballers.
Chris Stewart is offline
Old 01-30-2017, 09:22 PM
trayack
trayack's Avatar
Oh don't worry, I have a price I WILL sell it at, and a price I WON'T sell it at...
If I wanted to fire-sale this thing I could have sold it 12x's over in the mid 40's. I'd light it on fore purely out of spite before that happens. I've already turned down $50K BEFORE it was listed for sale so you gotta do better than that. Doing things like that not only lower the value/worth of MY car....but it also lower's the value of YOUR car too.
Right now, mine is the ONLY one in the country with the laundry list of mods. Its LPE pedigree/past, its proven performance, and (understated) capabilities, and its a magazine car etc etc. All of these things have value...I get that people who haven't tried to do these things won't get that and I'm ok with that fact. However, people who have, and who know.....will.
You can't come anywhere close to what this car can do and more importantly HOW this car does what it does for anything close to my asking price.
On a side note, my favorite flame comment from the 500hp+ FB page was the guy who said he could reproduce my full cage for $500. Buddy, I've literally got more than that ($600) in to JUST the trailer ball attachment hahah. The GTR nuttswingers are pretty comical too. "My GTR runs 10's blah blah blah." Cool bro, call me when it runs NHRA legal, pump gas 9.2s and let me know what your build cost is then
- Travis
trayack is offline
Old 02-05-2017, 07:25 PM
trayack
trayack's Avatar
Bump
trayack is offline
Old 02-11-2017, 01:34 AM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
Nice Vette.
~Josh is offline
trayack (02-13-2017)
Old 02-22-2017, 08:21 PM
trayack
trayack's Avatar
For anyone who's interested the car is currently at SlowHawk Performance in Bridgewater MA. Being torn apart for a cam swap at the moment. No more dinky ZR1 cam....hello more HP.
- Travis
trayack is offline
Old 02-22-2017, 09:16 PM
jclarksnakes
jclarksnakes's Avatar
Impressive car. GLWS.
jclarksnakes is offline
trayack (02-23-2017)
Old 02-22-2017, 11:10 PM
TWS Racing
TWS Racing's Avatar
Just saying "Completely sick car" doesn't go far enough. To build a car that quick and that well mannered both on the track and the street is no simple task and well beyond the abilities of the knuckle draggers who are trolling your for sale posts. They are broke and jealous and as they sit their picking their nose and hating on your ad, they have no idea how well built and clean your ride is compared to their zip-tied shade tree jalopy leaking oil in their front yard.
(Yes, I'm trying to sell a really nice car now too in case you couldn't tell. )
TWS Racing is offline
To The best of street/strip - 2001 lpe tt z06...
Old 02-23-2017, 01:26 AM
Chicago1
Chicago1's Avatar
I read about this car and heard about it. What a beast!!! GLWS..
Sidenote: and I mean tthis in the most respectful way but Holly **** on that first vid with that truck in the left!!!! That thing moved out!!!
Chicago1 is offline
Old 02-23-2017, 08:55 PM
trayack
trayack's Avatar
Thanks for the kind words guys. As cool as it might sound/look in writing and videos they really don't do the car justice. I've seen a lot of hot cars through out my time with Drag Week and I've yet to see one this mild mannered, let alone one that will run bracket like bottom 9's on pump gas. All its going to take is for one person to actually come see it and that will be it.
Just a fun fact....with the first owner and the 6spd in it this car has been 226mph in the mile. Jack of all trades would be an understatement.
I'm excited to see what the new cam will do to it, we are expecting a good amount to be honest. I'm not excited for the bill though, but hey....that's racing right?
If you're even considering this car there is no better time than now. When it's done at SlowHawk it will be completely fresh, as everything has to come out for the cam swap. There will be zero price increase, so I'm basically eating this one. Also, if you're serious about the car, this is the time to tell me if you want changes made while its apart!
- Travis
trayack is offline
Old 03-03-2017, 11:50 PM
zblkr1
zblkr1's Avatar
Awesome story/history almost put a tear in my eye, I don't even know you, but I want you to keep it haha.
best of luck
zblkr1 is offline
trayack (03-04-2017)
Quick Reply: The best of street/strip - 2001 lpe tt z06...
