1960 trunk won't open
Former Vendor
Key turns, does nothing.
Trunk will not open.
Spare and cover installed, trunk full of items.
Any suggestions as to how to release the latch ?
Thanks,
G
210-748-4693
Gropar@gvtc.com
Thanks,
G
210-748-4693
Gropar@gvtc.com
I have never done this myself, but read it from a very good source on this forum(can not remember who at the moment), you can punch the center out of the emblem by hand, using one fist to punch the other, then reach in the hole to release the lock. Chip
This. Search for the exact post. I had my latch bent and mine would not open. Exactly what you describe. While I did not ask I think this is what my mechanic ended up doing. It wasn't the key or the lock. Mine is a 60 also. Not sure how it bent, maybe if the trunk mat got caught or something. My trunk is hard to get it to latch, I have to slam it down a few times before it will catch so maybe the bending comes from some misalignment and slamming it over time.
First try pushing down very firmly on the trunk while turning the key. If some of that "trunk full of items" has slid against the latch and become lodged, you may have to push in the emblem like they said.
Here's a link to how it has been done in the past:
https://www.corvetteforum.com/forums...on-t-open.html
The following 4 users liked this post by 65GGvert:
I've had the same thing happen to my '55. As 65GGvert said, try pushing down on the hood to lessen the tension of the latch, then turn the key.
If something has slid against the latch, you may be able to drive it forward "quickly", hit the brakes, and move the items away from the latch. Worth a shot before you trash the emblem to get into the trunk... Good luck, don't break your key off in the cylinder, use a good key not a cheap copy, if you have one, less likely to break.
Jim
Jim
St. Jude Donor '07
when I locked my keys in the trunk I pushed in the emblem
AFTER you get it open, you might consider an electric trunk latch
Bill
Bill
It might be helpful if someone would post a photograph of the 1960 latch assembly so the OP knows what he's dealing with. I'd be happy to do so, but my '59 is long gone and my '61 lock mechanism is completely different.
the link I provided in my earlier post has pictures
Former Vendor
Okay,
I was able to "pop" the emblem ring off and get the trunk open.
The spring that retains the opening rod had disloged.
Thanks all,
G.
Thanks all,
G.
Tether Man
Received 2,014 Likes
2019 C1 of Year Finalist (appearance mods)
A couple hints - -
As stated, pushing down on the trunk helps take the pressure off.
I ended up adjusting my catch up a little and now my key turns
very easy. I had it to tight and the lock kept coming out.
Also, when re-installing your emblem, tap the top of the nuts to
close the hole back up. If the hole has opened up you'll never get
them to hold.
Larry
them to hold.
Larry
