Dumb ?? On closing your hood on your C7
Old 04-24-2017, 12:15 PM
maugust24
maugust24's Avatar
Default Dumb ?? On closing your hood on your C7
So I was watching a delivery today from the museum and the guy was showing how to close the hood. I always drop the hood to the hinges and push down above the hinge to lock one side and walk around and push the other side down. I have done this to my 2 C3's and now my C7. The gentleman that was doing the delivery made the gesture to not close it like I do and walked around the front of the car and push down on the center of the hood just above the vent and push the hood down about half way and give it a final push to close. It took them 4 times to get the hood latched on both sides doing it that way. How does everyone close the their lid?
Popular Reply
04-24-2017, 12:18 PM
juanvaldez
juanvaldez's Avatar
My delivery guy just dropped the hood from about a foot. I do the same thing. You will get the right height through trial and error.
Old 04-24-2017, 12:18 PM
juanvaldez
juanvaldez's Avatar
The following 11 users liked this post by juanvaldez:
bigsapper (04-24-2017), Bowmanr1 (04-24-2017), DAC17 (04-24-2017), ExRedRacer (04-24-2017), myc6toy (04-24-2017), sdurg24 (04-25-2017), snappy2u (04-24-2017), SpartaGus (04-25-2017), Tefer (05-16-2017), VictorBarron (04-26-2017), WhoIsPat (04-26-2017) and 6 others liked this post. (Show less...)
millpond
millpond's Avatar
I just drop it the last 2 feet. Works every time.
Old 04-24-2017, 12:19 PM
dbaker
dbaker's Avatar
Push mine down from the center with light pressure.
Latches properly & securely the first time.
\db2
Old 04-24-2017, 12:48 PM
bobs-z51
bobs-z51's Avatar
I do it the same way you do, walk around and do each side. That's how I always did it on my 65 conv.
Old 04-24-2017, 12:53 PM
ddlanes
ddlanes's Avatar
2023 C2 of the Year Winner - Unmodified
2022 C8 of the Year Finalist - Unmodified
2022 C1 of the Year Finalist - Unmodified
2018 C1 of Year Finalist
2016 C1 of the Year Finalist
Drop it straight down from about a foot, 6" on my C1. Pushing down on the hood would leave fingerprints!
The following 2 users liked this post by ddlanes:
ExRedRacer (04-24-2017), sdurg24 (04-25-2017)
Old 04-24-2017, 12:58 PM
davidtcpa
Go Canes!
Support Corvetteforum!
davidtcpa's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Old 04-24-2017, 01:02 PM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
I push with my knuckles just above the vent in the center of the hood.
Old 04-24-2017, 01:08 PM
Marcho Polo
Marcho Polo's Avatar
Received 1,620 Likes on 739 Posts
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
I slam the crap out of it as hard as I can! LOL
:smas h:
I close it to about a foot away, then press on the center top hard enough for both latches to catch.
Vicarious (05-15-2017)
Old 04-24-2017, 01:10 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
\db2
Same here. I'm afraid of damaging the hood if I push down on either corner after the hood is partially latched.
Old 04-24-2017, 01:14 PM
trivette
trivette's Avatar
Drop it the last 18" or so-never had a problem. Same way I do the C6. Even the C4 closes best using this method and that's a large heavy hood. My '59 I owned a few years ago was always a challenge and usually required a bit of 'encouragement' on one of the sides; once in a while the drop method would work, but not often.
Old 04-24-2017, 01:16 PM
HPT
HPT's Avatar
I very gently lower the hood onto the latches then use a rubber mallet to pound it home. Works great.
The following 3 users liked this post by HPT:
astaggs (04-24-2017), kenownr (04-25-2017), Rebel Yell (04-24-2017)
Old 04-24-2017, 01:17 PM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes on 2,065 Posts
2015 C7 of the Year Finalist
Close it down to the last 18", then drop it and let it latch on it's own. Don't push on the corner to complete the latching if it doesn't close completely. That means you didn't let it drop the last 18". It'll be fine.
Elmer
Old 04-24-2017, 01:43 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
I guess some here need a "power hood pull down". LOL.
Old 04-24-2017, 01:50 PM
Larry/car
Larry/car's Avatar
Lower hood to about 18 inches and with a gentle push let the hood fall on the latches. Locks in place every time.
Old 04-24-2017, 01:54 PM
maugust24
maugust24's Avatar
Lol I know that why I use a towel.
Old 04-24-2017, 01:56 PM
maugust24
maugust24's Avatar
To Dumb ?? On closing your hood on your C7
Old 04-24-2017, 02:00 PM
maugust24
maugust24's Avatar
I guess you and I are lone on this one. It's worked for me for years so I will continue.
Old 04-24-2017, 02:04 PM
L8ter
L8ter's Avatar
I just pull forward while I look out the window, it usually closes itself at, or about 10 miles an hour.
Old 04-24-2017, 02:13 PM
eboggs_jkvl
You will break the plastic if you continue to close it like that.
Just because you did it that way for years does not automatically make the procedure the proper way to do it on the new cars.
Just sayin...
Elmer
blue max (05-15-2017)
Quick Reply: Dumb ?? On closing your hood on your C7
