Now available at SCP: C7 Corvette Molded Acrylic Taillight Blackout Lens Package
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
2014-2019 C7 Corvette Molded Acrylic Taillight Blackout Lens Package
Adding a set of taillight blackouts is a great way to personalize you Corvette. However, with the new C7 Corvette a simple flat piece of acrylic plastic would no longer work they would have to be custom molded. Until now those molded blackouts for the C7 Corvette have been really expensive. We here at Southern Car Parts have been working with our suppliers to make a set of great looking blackout for the C7 Corvette that will not break the bank or look like it was made in somebody's garage.
Our molded acrylic taillight blackout package is just what you have been looking for. Each piece is molded in a die to fit the exact size, shape and contour of your factory tail lamps. These molded acrylic blackouts fit so precise they look like they were installed at the factory. The edges of our blackouts are flame finished for a smooth edge. Each C7 Corvette taillight blackout comes pretaped with 3M VHB, Clear adhesive. This clear tape cannot be seen when these blackouts are installed on your Corvette. Our taillight blackout package comes as a complete set of four covers, one for the driver outer lamp, driver inner lamp, passenger outer lamp and passenger inner lamp.
Application: 2014-2019C7 Corvette, Z06 and Grand Sport
Shown below on a granite counter top you can see how much light will show through the blackouts. Rest assured the people following your car will have no problems seeing your taillights when you press on your brakes.
Order here: 2014-2017 C7 Corvette Molded Acrylic Taillight Blackout Lens Package
__________________
rickmc17 (08-27-2019)
Supporting Vendor
Hello,
The lower carbon flash part of the rear fascia is separate from the body colored upper piece where the tail lights are located.
So no, these tail light blackouts will not affect the removal of the lower rear fascia for an exhaust install.
Supporting Vendor
Soooo much better than the garbage flat pieces of acrylic people are pawning off as tail light tint kit. These are purpose built v. some kid in his garage laughing his way to the bank.
or...
or...
