I'm 6'3" should i look for a 58-60 or 61-62?
During my C1 research here, it has been mentioned that the later C1's (61-62) have a bit more legroom. What is the consensus from the taller C1 crowd ?
I still REALLY like the rearend of the 58-60 over the duck-tail of the 61-62 but if i cant fit in it whats the point. Also, wanting an AT so working a clutch is not in the equation.
Thanks
FAST81
Thanks
FAST81
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
The seats in the 61-62 cars were totally redesigned and as a result, they are lower and go further rearward. Also, the transmission tunnel was reshaped. Thus, for sure, the 61-62 will provide more head and leg room.
Also, the 58-62 steering colums are shorter than the 53-57 columns.
SOOOOOOOOOO, with that said, IF you prefer the 58-60 body styles, AND, IF you could round up a set of 61-62 seats, those could be installed in a 58-60 car and provide the same head/leg room as a 61-62.
My personal opinion, I don't think you would be happy with a 58-60 if the top was on.
Oh ya, by the way, the 56-62 steering wheels have the same diameter, so there is no added room there.
Received 4,558 Likes
2021 C8 of the Year Finalist Unmodified
2019 C1 of Year Winner (performance mods)
2017 Corvette of the Year Finalist
2016 C2 of Year
2015 C3 of Year Finalist
Yes the 61, 62's have the most room of the Solid axles. I'm 6'1" and fit fine. Plenty of leg room. At 6'3" you should fit. You just have to duck going over bumps with the hard top on. You also have to slide you right leg flat/sideways under the steering wheel as you enter or exit.
Thanks
FAST81
Thanks
FAST81
At 22 years of age, 6'1" 235 lbs. I fit in my 61 corvette. At 70 and 190 lbs. I don't fit as well....or getting in or out is more difficult.
I solved that problem in 1970 by buying a 1966 convertible after I blew up the 61.
It will be tough shifting as your knees will hit the wheel unless you splay them sideways when you shift. Not so much with AT but you still have to sit with legs apart.
Get a c-2 for the most room..
Jack
I am 6'-2" & 230# & had the same issues. I fit & drive a 59 just fine, but I had to install a 700R4 automatic transmission because I didn't have knee room for the clutch. People here will rip on you for it, but the way I see it, its better to drive a c1 with an auto than have one in the garage with a clutch that I can't drive.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
61 and 2 are two inches longer on the interiour, but the head room is the thing. I hate driving my 62 with the soft top up, and I'm just 6ft. Any significant bumps in the road means you better duck or smack your noggin into the top bow.....and it hurts! :
Riding with the hardtop on is a lot better, but you have to duck to see out the side of the car and watch getting in and out for that really hard side trim...ouch!
If you're long waisted you'll also find yourself with the windshield top trim in your line of vision.
Mid years are a lot more pleasant comfort wise, especially for tall guys.
If you really want to maximize your room, you could buy the model year you like best, put your seats and frames in storage (or sell if it is not an NCRS car), get a 15" look alike steering wheel, and these seats:
http://www.alknochinteriors.com/stor...-lea-aok-seats
Or you can do what I did, and have Al Knoch rebuild your seats while taking out a couple of inches on the bottom and back.
Received 3,443 Likes
I'm 6'4", 290# and I've owned a '54, '57, '58, '60, 61, and a '62. The earlier cars are very tight and the later C1's do have more room, but I can't tell any difference between my 1960 which is long gone and the '62 I'm driving now. Everyone has different body dimensions. Longer or shorter torso, longer or shorter legs. I have to slide my butt forward to sit up in my '60 and '62. Even then my hair touches the hard top (hard tops give me more room than a convertible top). Bottom line is you need to sit in them, and realize there are modified seat options that may help, but they are still an acquired taste. BTW, I love them. See smiling face below.
St. Jude Donor '07
Bill
One thing I will say even if I had a manual the bend on the knees would just be too much never mind if I would have hit the wheel.
Some guys take the seats totally OUT and upholster the floor and bulkhead behind to make a seat. Max room, but I doubt they're very comfortable to ride in.
2016 C1 of Year Finalist
Myself being a normal height and weight ( 5' 7", 160 pounds) I have found that getting in and out of my 62 gets harder every year. The space inside is fine, it is a 4 speed and I have the seat halfway forward. The car is a hardtop only which helps.
My 57 with the hardtop is more difficult to enter and get out of and the steering wheel is way to close to be comfortable. A 15" fat guy wheel would help.
My 65 coupe is perfect and would easily accommodate a 6' 3", 230 pound person.
My advice is go with a C2.
Bruce B
Bruce B
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
Bruce B
Bruce B
I was in your situation a few years back, and was convinced to go the C2 Route.
I found a '67 vert, and didn't look back.
Sat in some C1s just to make sure, and its a bit cramped. After the initial "Holy Cow, I can't believe I am sitting in a C1" wore off, I was worried I'd get deep vein thrombosis after a 30 minute drive.
6'2" 250 (Long torso)
Cheers!
Cheers!
ohiovet (05-23-2017)
2018 C1 of Year Finalist
My friend is the same height as you. He has a 59 corvette and is able to drive it with the stock steering wheel. His corvette is a hardtop only. The convertible top comes down shorter... At least thats what it seems since it has the bows.
Now for 61/62:
Smaller seat frames.
doors are slightly longer than the rest. I think with exception to 60.
The accelerator pedal area has a slight indention.
Not sure if the tunnel area is smaller or larger.
You can fit in a 62 corvette. Try to find a local club and asked for a ride or at least sit in the driver's seat and see if you fit.
Keep in mind there is a proper way of getting in and out of a C1. Feet stays on the ground until your butt is planted in the seat. Then swing your legs into the cockpit. Same goes when you get out. Swing your legs out first onto the ground and then stand up.
Now for 61/62:
ptjsk (05-23-2017)
