courtesy lamps
Old 05-25-2017, 06:10 PM
Banksysvette
Banksysvette's Avatar
Default courtesy lamps
Hello there all,
I was wondering if anyone could help me find the missing half of the courtesy lamps wiring diagram 8A-53 that i currently have, as I have come across a short in the wiring somewhere that is blowing the crtsy fuse.
I recently replaced the drivers side headlamp gear because it too shorted out and kept opening and closing on its own.
I finally have a day off on saturday and would like to troubleshoot it and it definitely would be easier with the WHOLE wiring diagram.
Any help would be greatly appreciated. 1985 light and dark Bronze.
Thank you
Old 05-25-2017, 07:37 PM
gerardvg
gerardvg's Avatar
Originally Posted by Banksysvette
Hello there all,
Thank you
Hi
I have a courtesy lights diagram below from my 85 shop manual,
hope it helps.
Banksysvette (05-26-2017)
Old 05-26-2017, 09:47 AM
Banksysvette
hi there, i'm sorry but i don't see a diagram at all.
Probably i'm not looking in the right place?
Old 05-26-2017, 10:59 AM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
Explain exactly what you're interested in and maybe posting the 1/2 of whatever you say you have!!
Your reference to 8A-53 "hints" that's a "cell" in a GM FSM but there were no cell references in the '85 FSM and I've never seen any 8A-53 cell in any C4 FSM.
Post# 2 is what an '85 FSM should appear as.
Old 05-26-2017, 02:50 PM
Hot Rod Roy
Hot Rod Roy's Avatar
I was wondering if anyone could help me find the missing half of the courtesy lamps wiring diagram 8A-53 that I currently have.
Here's 8A-53 from my '84 FSM. Probably the same circuitry as the '85 FSM, but maybe the '85 has corrections!
Old 05-26-2017, 03:01 PM
Hot Rod Roy
I don't see a diagram at all.
The diagram displays just fine on my computer. What device and version are you using?
Old 05-26-2017, 04:21 PM
Banksysvette
Sorry about that Gerardvg, i was quickly looking at it on my work computer.
It probably doesnt have any software to open those photos.
I'm home now and just had a look at what you posted.
That's awesome, thank you so much. I love this forum as there always seems to be someone to help out. you guys are the best!!
Thanks again Gerardvg!
Old 05-26-2017, 05:00 PM
WVZR-1
WVZR-1's Avatar
I didn't look in any "older" C4 FSM - I did't believe the '85 had a 8A-xx cell arrangement so I checked randomly for "newer" and there were none. I believe anything '86 or newer will NOT have an 8A-53 reference.
It appears that in '84 it's only a page reference and NOT a cell!!
OP = do you actually have an '85 FSM that references 8A-53?
Old 05-27-2017, 08:34 AM
WVZR-1
WVZR-1's Avatar
OP - here's the "other half" of 8A-53 it's page 8A-52 from the '84 FSM. Will it help? I've absolutely no idea!
Old 05-27-2017, 08:45 AM
WVZR-1
WVZR-1's Avatar
Here's "BOTH" pages of CTSY from an '85 FSM
Name:  '85 CTSY 1.jpg
Name:  '85 CTSY 2.jpg
Old 05-27-2017, 11:46 AM
Banksysvette
WOW, you guys are fantastic!!
Thanks everyone.
This is going to help a lot!!
I will let you know when i find out where the short is.
Old 05-29-2017, 12:12 PM
Banksysvette
Thanks again to all who posted to help me out.
The short was in a wire leading up to the trouble lights underneath the hood.
A couple of fuses later and some new wiring and shrink tube and i'm good to go vroom vroom.
Chow for now!!
Old 05-29-2017, 01:10 PM
pcolt94
pcolt94's Avatar
Nice work as I have followed the thread.
Also the Forum thanks you for writing up the end result and to what the problem was.
I disconnected my hood lights years ago as when it open, it stays open for long periods of time and don’t want to worry about pulling down the battery and don’t need that little bit of light.
To courtesy lamps
Quick Reply: courtesy lamps
