C7 sway bars on Stingray model
I am starting to research a 2018 Stingray coupe non-Z51 and after reading several articles on the C7 and reviewing the forum comments, am I to understand that the base model does not come with any sway bars on the front and rear suspensions. Does the Z51 model have them installed as part of the option?
My C6 came with them but I upgraded them to the Z06 diameter sway bars.
I've had 2 base C7's now. The base model comes with a softer front sway bar than the Z51, and no rear sway bar. I upgraded both cars to the front to the Z51 bar and added the rear z51 bar. Relatively inexpensive and an easy install.
The Z51 comes standard with front and rear bars.
I'm considering changing to z51 (or Jonny O'connel) shocks next but kinda like having softer shocks with the condition of the roads around here!!
The following 2 users liked this post by 555ctsv:
McCarthy1986 (03-02-2020),
Mike's Sweet 19 (05-27-2017)
Received 1,762 Likes
GrayMatter2014 (11-13-2020)
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
The base shocks are 36 mm diameter. My 2014 Z51 did not have mag shocks, its Bilsteins are larger, 45 mm. They are tuned for the stiffer springs and larger sway bars. Typical of a performance shock the Bilsteins have complex valving to handle variable rate loads (but only as a none electronic controlled shock.)
Now have a Grand Sport that comes with mag shocks. The ride is softer set at Touring than my 2014, Z51-but not that much. Set at Track it is a much stiffer ride, even on our relatively smooth roads in Eastern SC.
The Z51 bars were the perfect upgrade for my base...made no other changes.
Flattens out the turns...doesn't impact straight line feel at all.
ZO6 bars, I thought, would be too strong absent other mods.
When I had my 2015 Stingray I installed the Z51 rear bar but retained the stock non-Z51 front bar. I posted a question here before doing it, and that prompted me to go ahead with the idea. It reduced understeer, body roll, and felt tighter in corners--but I never experienced any unexpected (non-power) oversteer. The standard front bar is only 1.8mm smaller in diameter than the Z51 counterpart.
DETAILS: With oversteer as the rear end is sliding off the road you must turn the wheel into the skid. If you turn the opposite way you just accelerate the rotation of the car and make the situation worse! The pic below shows both.
Having a modified '67 Corvair that had a Vette like parallelogram rear suspension, and although not a swing axle, the rear weight bias made it oversteer. GM even recommended 16 psi in the front tires in attempt to reduce front grip. Most folks never read the manual and did not use that low a pressure. This allowed Ralph Nader to write his famous book. In fact he used the '65 and later cars to condemn the swing axle early Corvairs!
My '67 with HD suspension, quick steering and Plus 1, 14 inch quality radial tires you still had to be prepared to quickly turn into the skid if driving aggressively in a tight turn. Frankly it was fun to anticipate what would happen and counter with steering before the car was out of shape.
We Corvair and old swing axle Porsche owners had a saying, "If you're going too fast into a turn, you're going to hit a tree so best to hit it with the rear rather than plow into it with the front!"
Johnny O shocks
Thanks for the tip. I have been looking for shock that is in the middle of soft and hard ride. Where are they available for purchase.
Z51 sway bar upgrade
