Info help needed
Old 05-27-2017, 06:52 PM
triple black vette
triple black vette's Avatar
Default Info help needed
I have a ls3 with a LPE GT12 cam installed. See photo of spec sheet, rockers 1.7, lifters a upgraded hydrolic roller. I am installing trick flow Genx 255 heads and not sure what length pushrods I should order. I'm guessing 7.700 or 7.750 ?
Your help will be much appreciated.
Thanks !
Old 05-27-2017, 08:51 PM
C6z06man
C6z06man's Avatar
You're going to need to use a pushrod length checker to get the correct length.
Old 05-27-2017, 09:32 PM
CMY SIX
CMY SIX's Avatar
I think you should be asking trick flow, they should know what length to use with their heads, they should tell you what gasket{thickness} you should use, doesn't matter what cam you have.
Old 05-27-2017, 10:39 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
So much wrong with this.
Old 05-28-2017, 11:25 AM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
Get a checker and order pushrods after unless you just get all the sizes that are "close" and return the ones you don't use.
To Info help needed
Quick Reply: Info help needed
