C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Stuck lifter... Now the upgraded 7.7
Old 06-16-2017, 10:37 AM
08Z
08Z's Avatar
Default Stuck lifter... Now the upgraded 7.7
I was driving on the way to an autox event and heard some ticking. Pulled over, pulled the valve covers and found a rocker loose. So I trailered it home and pulled the head only to find a stuck lifter.
We got it out by pulling the cam and pushing it back thru but the lifter bore needs to be bored and possibly sleeved if I wanted to reuse the block.
I really dont have much time to do that (in between events and im currently halfway thru a series) and even though it would have been the cheaper route Most likely I would have had them bore out the block and put bigger pistons in anyway...
So Im pulling the motor and putting a giant 7.7 468 in it. They guys started on assembling the motor yesterday and will be ready by next week. Also we will be putting a new center-force clutch in as well as a ported msd intake manifold, 52lbs injectors, a nick williams 102 throttle body, a dewitts radiator, new oil cooler, katech oil pump and a new cam.
Old 06-16-2017, 10:55 AM
Nowanker
Pro Mechanic
Nowanker's Avatar
Bore/stroke combo?
Which block are you going with?
Cam choice?
Should make sufficient power!
Old 06-16-2017, 11:02 AM
FNBADAZ06
FNBADAZ06's Avatar
What block are you using ?
08Z
08Z's Avatar
Originally Posted by Nowanker
Bore/stroke combo?
Cam choice?
So its a HPR short Block 4.185" bore and 4.250" stroke. All custom. Nothing they use is off the shelf all built to there specs. Same with Cam they are running numbers today to come up with the cam specs.
Old 06-16-2017, 01:47 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
What heads will you run? Will you go to 2" LT's (if you don't already run them)? Ported MSD...Mamo, or ??
Sorry for the misfortune...I enjoy following your threads and your use of unique parts combos. I'll be sure to follow this one as well.
Old 06-16-2017, 03:06 PM
08Z
08Z's Avatar
For now to save money I will reuse my WCCH Heads I recently purchased. The intake will be a ported msd with 52lbs injectors
Old 06-17-2017, 10:31 AM
Michael_D
Michael_D's Avatar
What's HPR? Is that a tall deck?
Old 06-18-2017, 03:07 PM
08Z
08Z's Avatar
HPR is a local Texas company. It's a regular LS block they use ls3 blocks and send them out to get re sleeved to bore out to spec.
Old 06-18-2017, 03:09 PM
Brandon619
Brandon619's Avatar
Keep us posted and take lots of pictures!
Old 06-18-2017, 03:21 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Horsepower Research
Erik Koenigs of HKE fame and Anthony formerly from LG.
Erik has been known as a world class LS engine builder forever. It is there new venture.
The following 2 users liked this post by Unreal:
HC Mechanic (06-22-2017), MTPZ06 (06-26-2017)
Old 06-18-2017, 05:38 PM
Michael_D
Michael_D's Avatar
Originally Posted by Unreal
Horsepower Research
I know Erik. I sent me nephew to SAM when he was teaching....
Didn't know he was getting back into the business. Glad to hear it.
Old 06-19-2017, 10:21 AM
08Z
08Z's Avatar
Yes as stated above Horse Power Research. Eric, Anthony and Terry.
Old 06-19-2017, 12:38 PM
08Z
08Z's Avatar
Assembly time! Block showed up this morning!!!
Old 06-19-2017, 02:30 PM
0HP RESEARCH
Former Vendor
HP RESEARCH's Avatar
I know you are going to be very pleased on the new powerplant in the Z. Of course HP on an engine of this size is going to be limited by the heads and smaller 1 7/8 headers but it is for sure going to be a much needed boost over what was in the car before. I know the build wasn't exactly planned at this point, but a good foundation is what matters!
Old 06-19-2017, 02:31 PM
0HP RESEARCH
Former Vendor
<--- We are HPR!
The 468 is the largest we can do within the dimensions of a stock LS/LT engine block currently. Using a tall deck RHS, or Dart we can go as large as a 527 cid
Old 06-19-2017, 05:14 PM
meanjoe
meanjoe's Avatar
Old 06-20-2017, 09:54 AM
chuntington101
chuntington101's Avatar
What the expected power from the 7.7?
To Stuck lifter... Now the upgraded 7.7
Old 06-20-2017, 10:26 AM
08Z
08Z's Avatar
Thats a good question. They have someone making a little over 740ish to the wheels but thats with bigger heads and carb set up. Im thinking with my heads and msd intake being the limiting factor we could see 650 or a little more to the tire its hard to say but we will find out very soon.
Old 06-20-2017, 10:35 AM
0HP RESEARCH
Former Vendor
-not a carb setup, but a more traditional style carb intake manifold...but they are still fuel injected. Those are typically much larger cylinder heads, Jesel shaft mount style valve train, 1500+cfm throttle bodies, and would require some hood modifications to go in a Corvette currently. A current FAST or MSD just does not have the air flow to support that kind of power with these big engines.
We are going to be doing a lot of testing with the 468 engine platform in a couple of local cars, one a BMW and the other a C6Z06 that will be the test bed for intake/head/cam development.
As time progresses we are very much planning on doing a number of in house designs more so than just the lower end of the engine and expanding into intake manifold designs because of the HUGE demand for air these big engines demand.
Old 06-20-2017, 11:27 AM
08Z
08Z's Avatar
What he said^^
Engine is pulled and ready for the transplant and the block is just... Well you can decide...
Quick Reply: [Z06] Stuck lifter... Now the upgraded 7.7
