i need a scanner!!!
Old 06-25-2017, 11:29 PM
mark970
mark970's Avatar
Default i need a scanner!!!
whats a good code reader on the cheap? i just picked up a 92 and i bought a 95 last summer so i wouldn't mind scanning codes myself instead of dropping $20 each time.
Old 06-25-2017, 11:53 PM
undervetted
undervetted's Avatar
The 1992 has OBD1 with a OBD 1 plug . The 95 has OBD1 but has a OBD2 plug. (16 pins) Now this is where it get fun, the 95 only has been pinned for OBD1 or 12 pins work. You would need a scanner for OBD 1 but also a plug adapter for OBD2.
I am sure you have noticed the ECM on the 95 is sealed. The 92 has a removable PROM. You can program the 95 with a computer from the plug. Not sure about the 92 the prom can be removed and reprogrammed and replaced, not sure if you can program the 92 through the plug.
I would recommend a BOSH http://www.oreillyauto.com/site/c/de...0664&ppt=C0103.
However it may be above what you want to pay. Good luck.
mark970 (06-25-2017)
Old 06-26-2017, 12:02 AM
mark970
mark970's Avatar
awesome, thanks for the info...yeah $300 is a bit much but i can do all or most of my own code reading (however in the 12 months i've owned my 95 its only thrown a code once and it was my fault for messing with the electrical system) and today i picked up a 92 so i thought its just a matter of time.
anyways i have an Oreilly's very close to home, i can keep that in mind.
THANKS for the link
Old 06-26-2017, 06:17 AM
hcbph
hcbph's Avatar
I've had an Innova scanner now for about 3-4 years. I don't see the one I have but it looks similar to this one: http://www.ebay.com/itm/Diagnostic-S...UAAOSwIgNXm6~s
I've used it on both ODB1 & 2 vehicles and it's worked just fine.
mark970 (06-26-2017)
Old 06-26-2017, 11:51 AM
Not4spd
Not4spd's Avatar
I just needed a code reader for the C4 We just picked up. I ordered this one for $23. Still waiting for it to arrive. https://m.summitracing.com/parts/INO-3123
Old 06-26-2017, 12:01 PM
mark970
mark970's Avatar
WOW that's a good price!! thanks
Old 06-26-2017, 12:27 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Why not just count the SES flashes?
mark970 (06-27-2017)
Old 06-27-2017, 03:38 AM
Cliff Harris
Cliff Harris's Avatar
You just bought an expensive paper clip. Try these links:
https://www.corvetteforum.com/forums...post1574918379
http://corvettephotographs.com/c4vettes/codes.htm
Old 06-27-2017, 10:40 AM
mark970
mark970's Avatar
Jr and Cliff..thanks for that info. i'm not a mechanic so i had no idea you could read your own codes just with a paperclip.
omg thanks so much...i will start a thread and talk about my code
Old 06-29-2017, 08:37 AM
aklim
aklim's Avatar
Received 2,234 Likes on 1,943 Posts
Here is the issue. The code doesn't tell all. Also the ECM is not very sophisticated as people think. It is better to get data streams and see what is going on. Most people seem to think that if they are in trouble, there must be a code. Not always. That is why I pay more for a scanner.
JrRifleCoach (06-29-2017)
Old 06-29-2017, 09:55 AM
yd328
yd328's Avatar
You can use a Snap On MT2500 on both cars. I bought one off of ebay. You just have to make sure it comes with the cartridges and connectors you need. The 92 & 95 have different connections, ALDL ports.
Gary
Old 06-29-2017, 10:41 AM
belairbrian
belairbrian's Avatar
I was looking at using an Android Tablet with either a Bluetooth or wired connector.
Found ASUS Nexus 7s for around $50 and a bluetooth adapter
Or maybe a USB cable for my laptop.
Anyone use either setup and if so what app/program.
Kind of leaning toward the tablet/Bluetooth for convenience when capturing live data
Old 06-29-2017, 10:43 AM
mark970
mark970's Avatar
good point, i will just have to research which one will be best for both of my cars.
Thanks for the input!
Old 06-30-2017, 12:26 AM
1993C4LT1
1993C4LT1's Avatar
You cannot go wrong with ALDL droid, and bluetooth adapter from 1320 electronics. Especially for 100 bucks total. I'll do a thread in the near days saying how to understand, and use it. This will let you read a code while you are data logging, if any codes are active. But it mostly used for real time data.
mark970 (06-30-2017)
Old 06-30-2017, 01:35 AM
mark970
mark970's Avatar
i will be looking for that thread!!
Old 06-30-2017, 09:54 AM
9T3VETTE
9T3VETTE's Avatar
[QUOTE=1993C4LT1;1595048656]You cannot go wrong with ALDL droid, and bluetooth adapter from 1320 electronics. Especially for 100 bucks total. I'll do a thread in the near days saying how to understand, and use it. This will let you read a code while you are data logging, if any codes are active. But it mostly used for real time data.[/QUOTE
Please do. I'm considering picking up a used android phone/tablet, dedicated for c4 data logging.
To i need a scanner!!!
Quick Reply: i need a scanner!!!
