C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Z06 H pipe autopsy
Old 07-21-2017, 09:12 PM
Mike44665
Support Corvetteforum!
Mike44665's Avatar
Default Z06 H pipe autopsy
I got around to opening one of these things up and here is what I found.
The path between the pipes looks better from the outside than what really is on the inside.
danziger (07-23-2017)
Old 07-22-2017, 10:08 AM
danziger
danziger's Avatar
I wasn't expecting a work of art, but that is pretty lame.
Old 07-22-2017, 11:12 AM
Mike44665
Mike44665's Avatar
I have another one here still intact, how would you suggest I do it, since this is "pretty lame".
Old 07-22-2017, 11:26 AM
Les
Les's Avatar
I think he was referring to the H pipe, not your efforts to depict it.
Landru (07-24-2017)
Old 07-22-2017, 01:45 PM
nuke61
nuke61's Avatar
That's how I read it too... the lameness was directed at Chevy's work.
Old 07-22-2017, 01:59 PM
Mike44665
Mike44665's Avatar
Well.........
If I didn't look like a dumb *** eariler, I pretty sure I do now.
Apologies Danziger.
Landru (07-24-2017)
Old 07-22-2017, 02:27 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
I swear I've seen this done before, and it was only like a 1" hole. Maybe that was on my C5Z?
Old 07-22-2017, 03:16 PM
nuke61
nuke61's Avatar
Yes, the C5Z H-pipe had
a small hole in it. Might have been 1" but it was significantly smaller than the pipe size. In comparison, it makes the C6Z H-pipe look fantastic.
MTPZ06 (07-22-2017)
Old 07-22-2017, 03:48 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
dont lose any sleep over it + crossovers are usually smaller in dia
dont buy the soup that a fancy H or X will give you any more power
Old 07-22-2017, 05:49 PM
dart.deanda
dart.deanda's Avatar
Default The right way
Back in the day you would run long pipes and spray paint them then start the car. Where the paint dried first is where the exhaust pulse its resonating in each pipe. Then make the connecting pipe go to each spot that dried because that is how you get the two pulses to add velocity, like adding two waves in phase as opposed to two waves crashing into each other. If that is not straight across, so be it, but that is how to get value out of an h pipe by taking advantage of the harmonics.
Old 07-23-2017, 01:36 AM
SonnyAK
SonnyAK's Avatar
Well.........
Apologies Danziger.
No worries! That's definitely an issue when reading what someone writes with no inflection or tone...It's crazy easy to for it to go one way or the other!
Old 07-23-2017, 08:21 AM
racerx3317
racerx3317's Avatar
Well, guess they had to cut corners somewhere to keep the price down. At least we can always go aftermarket.
Old 07-23-2017, 08:35 AM
danziger
danziger's Avatar
Well.........
Apologies Danziger.
Heh. No worries. I should have also thanked you for taking the time to perform the autopsy.
Old 07-23-2017, 11:13 AM
Dale1990
Dale1990's Avatar
St. Jude Donor '15
That actually looks better than I would have predicted.
Cool pics, BTW!
Old 07-23-2017, 12:17 PM
Mike44665
Mike44665's Avatar
If anybody's wondering how........
Band saw and patience.
nuke61 (07-23-2017)
Old 07-23-2017, 08:03 PM
MTPZ06
MTPZ06's Avatar
I assume you cut the H out to do an X conversion?
Old 07-23-2017, 09:20 PM
Mike44665
Mike44665's Avatar
Yes I did.
The for sale link.
https://www.corvetteforum.com/forums...to-x-pipe.html
To Z06 H pipe autopsy
Old 07-24-2017, 12:22 AM
butch353
butch353's Avatar
as an old pipefitter50+ years an former jet mech an part time racer 60+ learning what i have. I now use a back purge for stronger , an cleaner welds but more money out of pocket. have seen welds an cars that scared the hell out of me. one being the green monster with 1/2 inch crackes in the turbine disc. but we are all messing with thermal dynamics of moving air an learning how do our best. so leaned a hand to help some one increase their knowledge. Its up to them to do with it what they can an will. JD
Old 07-25-2017, 12:43 AM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
C6 of Year Finalist (performance mods) 2019
Art and Walt were crude geniuses who were willing to try anything. Lots of their stuff started as junk and most ended up that way too.
Old 07-25-2017, 01:09 AM
Les
Les's Avatar
How do the ends of the x pipe match up to the pipes at the weld points? Is it a good match or does it take some massaging to line them up cleanly? Thanks.
Quick Reply: [Z06] Z06 H pipe autopsy
