C1 clutch replacment /best brand
Just wondering what other c1 owners have used for clutch pressure plate kits , mild street use, last time out I used a Hayes street strip , with a Hayes steel flywheel that came with the car ,
the disk I removed is 10 1/2 inch and pressure plate , correct me but didn't the 61 corvette use a 11 inch disk and pp. the Hayes fly wheel has provisions for both , what difference does it make ? other brand I see are Zoom and Ram .
St. Jude Donor '07
Bill
Looking for a few more opinions on clutch kits used on C1 corvettes . ordering a fork spring from Zip and a pilot roller bearing , They seem to sell inexpensive clutch kits,
still like feed back . for now I am painting and detailing parts .
Received 2,127 Likes
For a street driven basic SB Vette, Luk 04-021 has been used by many of us guys. We have been warned NOT to use a roller pilot bearing. The Oilite bushing is highly recommended. Do a search on this and you will find much supporting information. Dennis
ill pass these gm parts along for pilot bushings 10125896/3752487 ,
7 years ago installed a roller bearing I remember having doubt , it held up well, this time iolite. Or equivalent,
Received 3,043 Likes
St. Jude Donor '05
My trans guy works on a lot of hot rods unless they are putting out big power he will always install the LUK .
Received 3,443 Likes
LUK is made by Sachs and is top quality stuff. Better than GM quality, in my experiences with it. My next clutch in any of my rides will be an LUK. Have installed many of them, and always had great pedal feel and holding power. And they never came back with issues, either.
Interesting. I saw an LUK kit and it said SACHS on the disc.
Take it from a guy that ran a Transmission shop from 1973 to 2015 when I retired. In 1990 another shop owner told me to try LUK clutch sets as we were having comebacks on the local parts house clutches.
From 1990 to 2015 we probably installed hundreds of LUK Repsets both foreign and domestic with not 1 fault.
Most of these were street driven vehicles. As long as the customer knew how to drive a clutch vehicle we were home free. No worries about a comeback.
If you want a quality clutch set, buy LUK as long as YOU install it correctly.
tach drive 61 (08-06-2017)
What can go wrong on a install ?? the only thing I didn't like so far with the luk kit ,throw out bearing didn't look to good , the non metallic pilot bushing works well with a magnet, summit sent me a 04084 that turned out to be a 10 inch disk but it bolts the the hays flywheel . Disk was made in Korea ! better be the south ! my sons in the army there now !
Just removed motor again clutch would not disengage ! I really think the fork I was sold by summit could be the trouble , the summit tech support guy said the pressure plate could be defective , they claim all the parts I was sold are correct for my 61 , We are using a hays fly wheel clutch kit 04084
I plan on using a Centerforce on my 61. Plan to use stock clutch linkage, Centerforce recommends I use their short throwout bearing. Anyone had experience with this short throwout bearing? Height is 1.24 inches.
Jerry - I just checked my old one out of my 61 and its 1.25" Stock LuK diaphram clutch.
jerry gollnick (08-11-2017)
