What is inside structural body cross member inside car behind seats?
I signed up for a Mid-Ohio track day in September and I want to mount my video camera on a tripod inside the vehicle. I would like to screw the mount into that structural cross member that is inside the vehicle covered in carpet and directly behind the front seats.
Does anyone know what is inside that thing? Can I use 2.5" long decking screws or should I drill though it and use a bolt and a nut?
Thanks, Mike
Thanks, Mike
My2002Z06 (07-23-2017)
Received 8,930 Likes
Yes, the fuel crossover tube is in there.
Bill
Bill
Visual
Looky see the crossover tube...
My2002Z06 (07-24-2017)
How big is the camera? Size, weight? Could you use a suction mount like some do with a GoPro? I have seen a number of cameras attached to the inside of the windshield to the right of the rear view mirror or even the upper right corner. There are also mounts that have a base plate that would allow you to attach it to the top of the dash using a suction mount.
It would be a good idea to add a retention strap or cord so if would come loose, it won't bounce around inside the car.
First of all what in the world would make you want to use a 2.5 inch long screw when the material is not even 3/16ths and on top of that a decking screw that is meant for wood in metal. Let's start with the right tools before we start hacking the car together
The following 2 users liked this post by v8srfun:
lionelhutz (07-24-2017),
Nope!! It is NOT higher.....
https://www.corvetteforum.com/forums...uge-issue.html
Then Post #3..................
Well that was the reason for my question. I had no idea how thick the material was. As far as I knew, it was solid with a foam core center. That is exactly why I sought out additional information. The forum replies were extremely helpful and provided the info I needed. Especially the photos!
