still having gas gauge issue
Old Jul 22, 2017 | 09:23 AM
woodvette03's Avatar
woodvette03
Default still having gas gauge issue
i am having the gas gauge issue where after i fill up, the needle goes to empty then sort of starts to work after driving a little while.
did 2 treatments with bg-44. poured in empty tank then filled up so it would flow to other tank. also did this with techron.
do i need to do something else at this point? it does not seem the sensor is getting cleaned.
thanks.
Old Jul 22, 2017 | 09:52 AM
SG Lou's Avatar
SG Lou
thanks.
Sometimes it take more then just 2 treatments. In my case it took around 4 or 5 fill ups along with Techron before it cleared up. Been good ever since.
Old Jul 22, 2017 | 12:01 PM
Mickeyrx70's Avatar
Mickeyrx70
In addition to following 8Vette7's advice, you might try a different gas station too, if you haven't already. I had the same problem a few years ago and tried the standard remedies without success until I switched from a nearby Chevron station to Shell. Probably a combination of things, but I haven't had a problem since.
Old Jul 23, 2017 | 09:46 AM
v8srfun's Avatar
v8srfun
If you have a shell near you there gas has the highest amount cleaner in it right out of the pump pair that with at least a 20 oz bottle of Techron every fill up and you will see a difference.
To still having gas gauge issue
