[C1] Lifter noise?
Lifter noise?
A short while ago, I had my engine rebuilt (283 with solid lifters, 097 cam). I've put about 400 miles on it and it has been running fine. Recently, however, I've noticed a significant tapping noise which seemingly is coming from the right side of the motor. The noise gets louder upon acceleration.
I decided to check the valve lash, which was all over the place. The spec calls for 0.010 intake and 0.015 exhaust, and I found some intakes as high as 0.015 and some exhausts as much as 0.024.
I adjusted all of the valves to spec, and hoped that it would solve the problem. However, there was no change in the tapping sound. Any idea what the problem might be and what I should look at next?
Received 6,943 Likes
2015 C2 of Year Finalist
does the heads have push in studs or screw in studs. double check them and that your rocker nuts are good. if those check out I would say your cam is going flat. have you checked your oil?
2018 C1 of Year Finalist
Good oil pressure? If not could be a rod knock. Almost the same sound. But first check the studs. Maybe wiped cam... Worth taking apart the oil filter.
Received 3,443 Likes
Stethescope time. Fuel pump, wrist pin, etc. You might try pulling ignition wires one at a time on that bank and see if the noise goes away. If so, it's a con rod bearing.
Received 1,919 Likes
Hope that's not your case. But if I had those symptoms I would park the car and drop the pan, and check #4 rod bearing (and all the rest while in there).
Hmmm...been a while but that's a test for rod knock... Not good.
If its been a 'short while' since the rebuild maybe you should pay a visit to the rebuilder and see what he/she says ?
If it was me I would call the person who did the rebuild. Do not do anything more than what you have done so far. Heck, a flatten cam or not I would still talk to the engine builder first before do anything more. Let them diagnose the problem first then go from there. Do not do the tear down.
Incorrect rod bearing clearances.
Not torquing down the rod bearing caps to spec.
Re-using connecting rod studs.
Lots of reasons to what could cause it to happen...
Ktholin (07-24-2017)
Received 3,043 Likes
St. Jude Donor '05
ck your exh gaskets & have your builder look at it
did you use an old cam & lifters?
Short of cam wear, I don't see any of the proposed causes changing the valve lash - there is still something going on there.
engine noise
As to a flattened cam lobe, the rocker arm would have little movement and the engine would probably skip like you had a dead cylinder. Hope your engine built was warrantied.
