MN6 Rear End Oil Change
Old 08-17-2017, 12:19 AM
MrLeadFoot
MrLeadFoot's Avatar
Default MN6 Rear End Oil Change
Haven't done this before but someone told me not to attempt it myself at home because it is messy, and if I spill anything, it'll stink to high heaven forever. Trouble is, who can I trust to do it right? Any tips for me? Better yet, anyone in the Sacramento area want to help me?
Old 08-17-2017, 02:55 AM
chain_5001
chain_5001's Avatar
Just make sure you loosen the fill plug first just in case its stuck before draining the fluid. Get one of those large oil drain pan and put down cardboard if you're concerned about spillage.
Old 08-17-2017, 07:47 AM
bigcypress
bigcypress's Avatar
this is just MY OPINION , i can't recommend g m fluid . had mine changed at a chevy dealer about 3 or 4 years ago and about 1400 miles ago and if anything the noise is worse . just had more additive put in [ dealer said it could not be done ] and will see what happens . my next attempt will be to have amsoil fluid and their additive put in . . . peace
Old 08-17-2017, 09:38 AM
jmohn
jmohn's Avatar
Changing the diff. and tranny fluids are a piece of cake. The part of the job that takes the longest is getting the car up on nice stable jack-stands and reasonably level.
If you can do an oil change, you can do the diff. and tranny (they're actually easier).
Do loosen the fill plugs first, be sure you remove the "correct" drain and fill plugs (do a search on this site for pic's if you're not sure).
Re-fill with the lube of your choice; I found it easiest to just order the recommended Amsoil products (and the pump that fits on the lube bottle). Again, do a search on this site, there's a couple of write-ups that walk you through it very nicely.
The stink thing is a matter of opinion; gear lube just smells different than motor oil and it all cleans up with soap and water.
Old 08-17-2017, 09:45 AM
runner140*
Support Corvetteforum!
runner140*'s Avatar
Its NOT a dealership project...do it yourself. If you can change your oil, you can do a diff. oil change. Not sure? Do a YouTube search on it. Its pretty simple. I just did mine so if you still aren't sure, P.M. me and we will talk.
Old 08-17-2017, 10:29 AM
chain_5001
chain_5001's Avatar
You don't even need to jack the car up. You can do it on the floor. Get a drain pan that's low enough to get under there and get one of those pumps that fit on the gear oil bottles to pump in the fluid.
Old 08-17-2017, 11:15 AM
MrLeadFoot
MrLeadFoot's Avatar
OK, thanks everyone. Locally, it seems I am quite limited in lube options. GM, Royal Purple, Lucas Oil, Mobil 1, Valvoline. Not sure about the GM stuff, but the others are synthetic. Would you do any of these or order something else?
Old 08-17-2017, 02:02 PM
lane_viper
lane_viper's Avatar
I use Mobile 1 in both the S2k and Vette. Make sure it has the additive and you're golden.
Old 08-17-2017, 02:07 PM
RBS_Z51C5
RBS_Z51C5's Avatar
I used the same stuff (75w-90?) with the limited slip additive already in it 3 months ago and it works great! I didn't lift the car either. It only took 15-20 minutes tops. I got a gear oil hand pump from Harbor Freight and no problems whatsoever.
acuevo
acuevo's Avatar
If anything the trans fluid will make more of a mess. It came out harder than i expected and my arm took a bath in it when i did mine.
Old 08-17-2017, 02:35 PM
chain_5001
chain_5001's Avatar
Most car nerds like to use gear oil without the limited slip additive. That way they can add the amount that suits their cars and driving habits.
Old 08-17-2017, 04:48 PM
MrLeadFoot
MrLeadFoot's Avatar
Is that what you do?
Old 08-17-2017, 04:52 PM
MrLeadFoot
MrLeadFoot's Avatar
Are you guys serious about not having to jack it up? That sure would make it easy to not have to worry about leveling when jacking the whole car up. As someone who has not done it before who's 5'9", 185 lbs., would I have room enough to maneuver under there? If I were to drive it up onto 2x10s, would that help any?
Also, someone on another post said you can use just the shaft of a 3/8" ratchet drive to loosen the plugs, but someone else said it requires 10mm hex on a socket. Which is correct?
Old 08-17-2017, 05:09 PM
chain_5001
chain_5001's Avatar
Yes, I am of course the biggest nerd. It's a 10mm allen to remove the drain/fill plugs. You should be able to see it.
Old 08-17-2017, 06:12 PM
MrLeadFoot
MrLeadFoot's Avatar
Old 08-17-2017, 08:00 PM
001pewter
001pewter's Avatar
St.. Jude Donor '17-'18
Old 08-17-2017, 08:35 PM
pjdbm
pjdbm's Avatar
This job would be perfect to schedule when you change the oil, the car will already be up in the air. For the first time doing it, I would recommend the car being up, at least you will be able to see exactly what you are doing AND cleaning, before and after.
I used Amsoil severe synthetic gear oil and purchased the pump for $10.00 from them. I did not have to add the limited slip oil but purchased just to have on hand just in case.
This is one of the easiest jobs Ive done on my vette, in fact, my next oil change, when its up in the air, I will repeat the oil change so I know I got all the old fluid out.
dont forget the break in after you do this
To MN6 Rear End Oil Change
Old 08-17-2017, 10:12 PM
MrLeadFoot
MrLeadFoot's Avatar
I don't think anyone mentioned it, and I forgot to ask how much oil I need.
Old 08-17-2017, 10:15 PM
chain_5001
chain_5001's Avatar
Get 2 quarts. It'll take about 1.8 quarts to fill.
Old 08-17-2017, 10:22 PM
Joepro95
Joepro95's Avatar
red line has the additive in it, also they have a slightly thicker fluid now a 75w110 if you have any noise it may help. Red line hasn't let me down.
https://www.redlineoil.com/product.aspx?pid=133&pcid=4
https://www.redlineoil.com/product.aspx?pid=147&pcid=4
Quick Reply: MN6 Rear End Oil Change
