Front-end winch attachment?
Received 1,126 Likes
I have a tilting Aluma trailer which I've been driving onto with mixed results. It's not easy feathering the clutch and gas on a 20 degree slope to get positioned. In fact it feels kind of dangerous and more importantly, I'm gradually destroying the clutch.
Installing a winch on the trailer is easy enough but I'm stuck on the best way to pull the car up. Ideally I just want to hook the winch to something and haul it up.
I've looked at the front end a bit and the place where the bumperettes attach looks to be a fairly sturdy place to put an adapter plate with a tow ring. Looks like I could have four bolts on that crossmember and I wouldn't unduly strain the radiator, which would be my chief concern. I'm thinking I may be able to get the ring to protrude behind the license plate, which would minimize any torque on the crossmember.
Has anybody here installed anything along these lines and what specifically did you do?
I'm in the same boat. I'm looking a little more toward the rear and making a tab to bolt to the frame closer to the cross member where the frame is a bit more sturdy. My thought is that pulling on a corner is not good. Unless you want a diamond shape frame.
In loading the car, I put a couple of flags up on the corners of the trailer to sort of see where I'm going, as I can't really see over the hood (your hood actually!).
If I do fab something, are you interested in a copy?
Nam Labrat
Received 4,178 Likes
Rookie suggestion:
How about attaching a dedicated strap across from one lower A-arm to the other.....then connect the winch cable hook to the center of the strap.
The cable will be much lower which will clear the spoiler, and you can't bend a thing on A-arms!
I've had that thought especially since I have tubular A-arms. But these days I am all about not having to crawl under the car, especially when it's flat on the ground. It's not that bad hooking up the restraints when the car is up on the trailer but that's it. I'm willing to do some work to make autoX days a bit easier.
Are you thinking of something like this, which is two pieces?
The bracket attaches to solid structure and the red tow ring in detachable.
It looks like it could mount directly under the front license plate.
Nam Labrat
The attachment Wendell posted looks promising....it could be permanently attached/the winch hook could be attached using a pole similar to a broom handle which would save you from having to crawl under the front to attach it to the "eye".
RVZIO
Senior Member
Received 2,031 Likes
St. Jude Donor '10
I use two straps, one around each lower control arm, and hook to the tow cable hook. Works well. I don't drive cars onto the trailer, I winch them.
Best regards,
David
Best regards,
David
I hate to drill holes or weld to my frame if I can find another way. I was thinking maybe I could attach a piece of plate steel to the four bolts in in my cross member that right now hold the angle brackets to the bumperettes. Then have something that reaches up behind the license plate to hold a a tow ring/eye. Maybe hinge the license plate somehow to get access.
Searching on "tow eye" gets me lots of interesting imagery something like Wendell shows.
I have straps I wrap around the A-Arms and a bridle I attach with shackles
Here's a thread from a while back in which a member added something similar to his later model C3.
https://www.corvetteforum.com/forums...-tow-hook.html
Pulling the car up a 20 degree ramp should be about a 1000 # load on that member. It doesn't seem unreasonable.
