Range Technology 8.4
Old 09-15-2017, 01:06 PM
50th year
50th year's Avatar
2017 C7 of Year Finalist
Default Range Technology 8.4
I just talked to Range Technology and they say they are shipping 8.4. They said that the beta versions will be odd numbers and shipping will be even numbers and they are now shipping 8.4. It seems like a short time for beta testing. They think they have it worked out. We will see.
Old 09-15-2017, 01:13 PM
mountainears
Support Corvetteforum!
mountainears's Avatar
Yea, interesting that they say they are now shipping 8.4 when I just received an 8.3 beta last week. They must be confident. Just started using it today. Will drive the car a few times this weekend and will report back, hopefully they have it this time. Their track record has not been great.
Thunder22 (09-15-2017)
Old 09-15-2017, 04:13 PM
mountainears
Well that only took a few restarts and I got a CEL again on my 17 GS. If 8.4 is the same code I'm not optimistic.
Old 09-15-2017, 04:57 PM
50th year
50th year's Avatar
Not good
Have you informed Range about the CEL?
It seems like the only solution is the on off switch
Old 09-15-2017, 05:00 PM
rmorin1249
rmorin1249's Avatar
Received 1,738 Likes on 1,174 Posts
St. Jude Donor '15-'16,'18
Crap, I was hoping for good news. I guess 8.4 is what will be on mine when it comes back. Time will tell. Do you leave yours plugged in and turned on when you start your car?
Old 09-15-2017, 06:00 PM
mountainears
Range has been informed.
When I first started it I plugged it in after. The three subsequent restarts the range unit was plugged in before starting. CEL occurred on the 4th start.
Old 09-15-2017, 07:01 PM
Jaylars
Jaylars's Avatar
Originally Posted by 50th year
Not good
Agreed. switch works like a champ! I have been using V8.2R1 for over a month now and have not had any issues. (2017 GS)
I have been using the simple switch technique;
1. start car
2. wait till phone and wifi is detected and idle levels out
3. switch Range on and wait for the solid blue light and go.
Prior to shutting the engine down, switch the range off. Have not had any issues in over 2000 miles.
The following 2 users liked this post by Jaylars:
Rebel Yell (09-16-2017), vbdenny (10-08-2017)
Old 09-15-2017, 07:14 PM
rmorin1249
rmorin1249's Avatar
I can live with having to turn the Range on AFTER the car is started and then turning it off before the car is shut down. My problem is remembering to do just that. I blame it on senior moments.
Old 09-15-2017, 07:19 PM
50th year
50th year's Avatar
1. start car
Where have you located your switch? I have tried a dozen ways and nothing seems to be right. I am researching some kinda adhesive for the switch but don't want to screw up the dash. Something that can hold and still be removed without leaving marks would be ideal.
Old 09-15-2017, 07:27 PM
rmorin1249
rmorin1249's Avatar
I ran the cord behind the drivers side kick plate and then along the outboard side of the drivers seat. I used velcro to attach the switch and Range to the carpet. I can reach down and turn the switch on and off and also glance down and see the lights on the Range. I tried putting it under the dash but didn't like seeing the lights while driving especially at night. I would take a photo but my unit is at Range being updated. I am pretty sure there are others who have done a similar setup because I copied their idea.
50th year (09-15-2017)
Old 09-15-2017, 07:29 PM
mountainears
Not a big deal, but I believe that if you are powering up the range device after the car start it will clear any codes that your car has. So just be sure to check for any check engine lights or other issues before powering it up as it could reset them (ones you might want to keep).
Old 09-15-2017, 10:35 PM
Patman
Patman's Avatar
Received 1,920 Likes on 1,192 Posts
1. start car
I can understand waiting to turn the unit on for a little while but why does it need to be shut down prior to the engine shutting off? Will that really make any difference as long as the startup procedure is followed?
I'm still waiting to hear back from Range as to when this unit will be compatible with 2018 Corvettes. (I'm sure there wasn't any tuning difference between a 2017 and 2018, but I'd still rather hear from Range that the unit is compatible before being a guinea pig)
Old 09-16-2017, 12:17 AM
mountainears
They can't get it right for the 2017's yet and but they will likely say that it is, but you'll take their word for it on the 2018's?
So far with the 2017's, the car that seems to be mostly impacted is the Grand Sport.
Old 09-16-2017, 12:32 AM
Foosh
Foosh's Avatar
Received 16,668 Likes on 8,311 Posts
Why would the GS be any different than the Stingray with an identical engine and ECM?
Old 09-16-2017, 12:37 AM
Onrails
Onrails's Avatar
how is this company still in business? Their product is garbage! If you want to send your device in for constant updates with no guarantee of success,by all means send them your money.
Old 09-16-2017, 01:06 AM
mountainears
No clue, but I have been following this for a while and it seems more of the people that are still truly getting CEL's are those with GS'. I could certainly be wrong, but it is the sense I'm getting.
Definitely something more of an issue with 2017's though....something changed in that MY, will be interesting to see if 2018's are equally plagued by them.
mountainears
My understanding is that everyone except 2017's should be working fine at this point with the latest revisions.
Maxie2U (09-17-2017)
To Range Technology 8.4
Old 09-16-2017, 01:21 AM
Foosh
Foosh's Avatar
I'd guess those are the ones most likely purchasing these now and reporting their problems on this forum. There are no ECM programming differences between LT1-equipped models that would cause this.
Old 09-16-2017, 06:56 AM
Patman
Patman's Avatar
They should redo this device with either a manual switch built right into it, making it easier for people to turn it on and off, or they should set it up so that it automatically is off when the car is shut down and doesn't power up until about 15-20 seconds after the car is started. This alone could improve the reliability of the unit drastically.
The following 3 users liked this post by Patman:
767guy (09-18-2017), beaversstonehaven (09-16-2017), Maxie2U (09-17-2017)
Old 09-16-2017, 07:03 AM
red 1
red 1's Avatar
No my 15 would still get CEL's regularly with the latest version Range, Diablo I2030 tune took care of it by turning DOD/AFM off.
Quick Reply: Range Technology 8.4
