On3 Turbo Build
On3 Turbo Build
Finally picked up an On3 kit! I know everyone has been curious about this kit, everything looks very well put together. I'm not sure when I will be digging into the actual build, there are still a couple trips I have planned with my car so it might be a couple weeks before I start.
I want to run E85 so the plan is DMS flex fuel kit, walbro 450, BAP and injectors. Not sure on what injectors to get, any recommendations? I would like to be around 600whp for now but have the fuel to support 800 later on.
That kit looks so nice! I think I may jump on that this coming year. Even if the turbos crap out, you can replace the CHRAs with Garrett units.I have been on the fence between ECS/AA and this option. I really like the idea of turbos over the blower.
I'm sure this kit will take more time to put on then a regular blower but I'm hoping the power cure is a lot smoother then a regular aa kit or procharger
I have heard of a couple people but no real information from them, I'm not sure what turbos will swap with their housings. From what IV read these turbos have about the same specs as the Hurron C5 kit?
I purchased this kit from a forum member but as far as I know they are still making this kit. I would assume if they went to single it would be just like cx racing kit with no ac or bumper exit.
Received 1,194 Likes
St. Jude Donor '15
How much are these kits running?
St. Jude Donor '15
Damn that’s a cheap turbo kit
How much power should it be good for? The torque of turbos sure is fun.
It’s unlikely I’ll feel like screwing with my setup anytime soon but still interested to see how this option works out
You should be able to find ID1300X’s for a bit cheaper than that unless they’ve gone up since last time I looked for some
I'm not sure power wise, theoretical it's the same principle as a trixx or hurron kit with close to the same turbos. Somewhat same to a UPP kit too, and they are making anywhere from 500-1000. I'm thinking around 800 is where it will peak on this kit. Guess we'll find out.
What's wrong with fast or bosch injectors? Around $600 for 80lb, don't wanna skimp on but don't need the craziest stuff either....
Big injectors (1000cc or better) tend to idle/cruise poorly in low demand scenarios. The ID injectors are mapped very well and have stock like manners in the same conditions. E85 helps alleviate the symptoms as the demand per rev is 33% higher than 93 for a given volume of air. YMMV
