Need Picture/Dimenisons, Console Lid Latch
Old 10-18-2017, 10:15 AM
PCMusicGuy
PCMusicGuy's Avatar
Default Need Picture/Dimenisons, Console Lid Latch
My friend is working on a model for the console lid latch, and since my piece is broken where it secures and I cannot find the pieces, I don't remember what it looks like. If someone would be so kind as to take some pictures of their intact factory latch I would be most appreciative. If you could provide some dimensions on the latch piece that would help even more. Everything else is modeled to scale, just missing this last piece.
The end goal of this is to have a 3D printable model so we no longer have to pay $40+ for a stupid piece of plastic bound to break again. Thanks in advance.
Old 10-20-2017, 11:57 AM
PCMusicGuy
PCMusicGuy's Avatar
Come on guys. Just a picture or two.
Old 10-20-2017, 12:04 PM
Frankie15
Frankie15's Avatar
I would definitely appreciate this. I would take a pic for you, but mine is broken as well.
Old 10-20-2017, 12:09 PM
Turbo6TA
Turbo6TA's Avatar
Received 3,087 Likes on 2,078 Posts
I am in the same boat as 'Frankie' .... I have a 2011 GS and my center console cover latch is broken too.
PCMusicGuy .... Good luck on this
Old 10-20-2017, 12:13 PM
OregonMike
OregonMike's Avatar
Didn't see this thread until this morning. I'll grab pics and dimensions this afternoon if nobody gets them before then.
The following 3 users liked this post by OregonMike:
Frankie15 (10-20-2017), Racer1735 (10-20-2017), Turbo6TA (10-20-2017)
Old 10-20-2017, 11:35 PM
Racer1735
Racer1735's Avatar
I thought the lid latch was supposed to be broken?
Old 10-21-2017, 12:14 AM
PCMusicGuy
PCMusicGuy's Avatar
A very common problem it seems. I haven't found the broken piece of my latch yet. I am pretty sure I kept the piece, I just don't know where.
Old 10-21-2017, 05:20 AM
Detroit1
Detroit1's Avatar
Default Latch
Bought my GS last year. Latch broke as stated. I used Velcro latch to keep it closed. Would really like to replace the latch if someone is going to create one.
Jim
Old 10-21-2017, 11:41 AM
72GACRZR
72GACRZR's Avatar
Have you gotten what you needed? I have a base 2008 convertible and have taken some pictures and measurements best as I can.
Old 10-21-2017, 12:02 PM
72GACRZR
72GACRZR's Avatar
Here is one picture, the rectangle with the tab is 2 inches left to right and 6/8 inches top to curve at bottom of tab and goes between the lids top cover and base 6/8 inches best I can get the measure in. The top of the little tab is 8/32 inches out from the base and 6/16 inches wide.
Old 10-21-2017, 12:22 PM
PCMusicGuy
PCMusicGuy's Avatar
Thanks. I have the latch with the piece broke off so I can see where it goes on the piece and event the dimensions of where it connects, or in this case, breaks off. I was mostly looking for a few pictures of the latch from different angles, and then getting the dimensions from the hook portion of the latch. I've seen a picture on Cultrag's site that shows a picture of the latch, but it has gussets on the back side to keep it from breaking. I've never seen one like this in the wild and when I take a stab at 3D printing a new one, I want to make sure it is designed so that it doesn't break again.
Old 10-21-2017, 01:48 PM
doomi
doomi's Avatar
Here you go. Measurements aren't dead on as it's kind of hard to grab some of the parts.
The latch is 8.28 mm tall and 10.58 mm wide. The actual catch is 7.49 mm deep.
The following 2 users liked this post by doomi:
Frankie15 (10-21-2017), OregonMike (10-21-2017)
Old 10-21-2017, 01:52 PM
OregonMike
OregonMike's Avatar
Thanks and great job doomi
Was just headed back out with the dead calipers to check measurements when I figured I'd check in to see what exactly needed measured & you've already posted
Old 10-21-2017, 07:22 PM
Frankie15
Frankie15's Avatar
Thanks Doomi! Hopefully we can get these made. Would be great.
Old 10-22-2017, 01:32 AM
PCMusicGuy
PCMusicGuy's Avatar
Thanks man! I will let you guys know how it goes.
Frankie15 (10-23-2017)
Old 12-16-2017, 11:35 PM
Frankie15
Frankie15's Avatar
Anything ever come of this?
Old 12-19-2017, 09:57 AM
PCMusicGuy
PCMusicGuy's Avatar
Still working on it. The model is finished and just needs to be printed with whatever supports are needed. A bit busy with holiday time right now but I believe I'll have something in January.
The following 2 users liked this post by PCMusicGuy:
fireparamed (12-19-2017), Vet Interested (12-19-2017)
To Need Picture/Dimenisons, Console Lid Latch
Old 05-13-2018, 09:18 AM
dillihag
2nd Gear
dillihag's Avatar
Bump! Are you able to share the file? I will draw one up today if not, might save me a couple of hours!
Old 05-14-2018, 11:22 AM
PCMusicGuy
PCMusicGuy's Avatar
I have uploaded to Thingiverse but it won't be available for 24 hours since I'm still considered a new member. I can email the STL file to those who need it sooner, just PM me. I have one more STL file that is in the works to smooth out some of the sharper edges. Once I print that one, I will determine if the changes are beneficial to the final model.
Old 05-14-2018, 01:36 PM
bibbster
bibbster's Avatar
This is great! Our latch is broken too. I have access to a printer, just need a file.
Quick Reply: Need Picture/Dimenisons, Console Lid Latch
