[C2] before body drop
Old 10-21-2017, 10:43 AM
bigal883
bigal883's Avatar
Default before body drop
Hi need a little info on what has to be installed items before body drop. what abosultly has to go in first .throttle link, heater box assembly , emblems , antenna? have radiator support in, can you put shroud on? most of items in engine compartment have been finished. mufflers on or pulled in? working outside have to have body on before snow falls. Help. bigal883.
Old 10-21-2017, 11:23 AM
MasterDave
Moderator
MasterDave's Avatar
C2 body drops are easy enough. Can't think of anything that has to be in/on the body prior to drop. Leave the exhaust panel off the rear of the body to allow for exhaust to clear. Leave the fan shroud off IMO.
bigal883 (10-21-2017)
Old 10-21-2017, 11:27 AM
leif.anderson93
leif.anderson93's Avatar
Received 3,098 Likes on 1,866 Posts
Hi need a little info on what has to be installed items before body drop. what abosultely has to go in first .throttle link, heater box assembly , emblems , antenna? have radiator support in, can you put shroud on? most of items in engine compartment have been finished. mufflers on or pulled in? working outside have to have body on before snow falls. Help. bigal883.
I believe you've got it covered with the items you mentioned. Radiator shroud should be able to be in place. Is the drive train already installed on the chassis?
Old 10-21-2017, 11:45 AM
bigal883
bigal883's Avatar
Default thanks for info
Yes complete drive train engine finished rolling chasis thanks. bigal883
Old 10-21-2017, 12:59 PM
leif.anderson93
MAY have fan to shroud interference if shroud is installed. I would remove the fan from the engine to allow clearance and leave the shroud in place.
Old 10-21-2017, 01:08 PM
packrat
packrat's Avatar
Default Before body drop
I would also install the fiber insulation piece on the body tunnel above the transmission
To before body drop
Quick Reply: [C2] before body drop
