Mantic clutch install questions...
Old 12-29-2017, 10:42 PM
C U IN REARVEIW
C U IN REARVEIW's Avatar
Default Mantic clutch install questions...
Doing a mantic 9000 twin disc clutch...
-do I need to get new flywheel bolts?
-red or blue loctite on flywheel bolts? On clutch bolts?
-what to clean surfaces with?
Thanks.
Old 12-29-2017, 11:34 PM
Turbo2L
Turbo2L's Avatar
I went with new flywheel bolts and red loctite. I put a small amount of blue loctite on the clutch/pressure plate bolts for my own piece of mind. I'd make an effort not to get anything oily or greasy, particularly in regards to the the disks.
Old 12-30-2017, 12:07 AM
C U IN REARVEIW
Says to clean surfaces with a acetone based product that leave NO residue
Old 12-30-2017, 10:19 AM
russ472
Support Corvetteforum!
russ472's Avatar
i would use brake cleaner
Old 12-30-2017, 10:38 AM
C U IN REARVEIW
I was told lacquer thinner also.....?
Old 12-30-2017, 12:01 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Brake cleaner
My mantics always came with new flywheel bolts. Not sure if that changed. The new ones have thread locker on them already.
Old 12-30-2017, 12:25 PM
C U IN REARVEIW
Originally Posted by Unreal
Brake cleaner
Damn....not sure how I missed those bolts....lol! Thanks as ALWAYS for your help
Old 12-30-2017, 12:44 PM
C U IN REARVEIW
Bolts have thread sealer on them....need any additional sealer?
Old 12-30-2017, 12:52 PM
Mike's LS3
Mike's LS3's Avatar
About 1 1/2 years ago I bought the Mantic 9000 twin disc and it came with everything: Flywheel, bolts, discs, pressure plate, align tool and GM slave cylinder. The bolts already had the thread locker.
Pick up some brake cleaner, pilot bushing and a remote bleeder and you should be good to go.
Old 12-30-2017, 01:01 PM
Unreal
Unreal's Avatar
No additional sealer needed. Just use what it comes with.
Old 12-30-2017, 02:05 PM
C U IN REARVEIW
Got bleeder already....time to put this PITA back together
Old 12-30-2017, 05:11 PM
C U IN REARVEIW
Any tricks to removing the pilot bearing?
Old 12-31-2017, 12:31 PM
Tech
Tech's Avatar
You can rent the tool + slide hammer from Autozone. I usually have to grind a bit on the tool to get it to fit in the ID of the bearing.
Old 12-31-2017, 03:07 PM
C U IN REARVEIW
I had to do the same....but got it out finally!
Old 12-31-2017, 08:56 PM
548chevelle
548chevelle's Avatar
Best trick is to get four 3-4 inch long bolts same thread size as the torque tube to bellhousing bolts. Don't recall what size but cheap hardware store type work fine. Cut off heads and screw bolts into bell housing. The torque tube will then align perfectly when putting it back together. Otherwise the slightest misalignment could ruin the clutch discs as you try getting the spline shaft to slide into the discs.
Old 12-31-2017, 09:39 PM
Tech
Tech's Avatar
The last time I did a clutch, I disassembled the torque tube. Its just one large c-clip on the back. Then install the slave, measure for shims, shim (if needed), then install the slave+torque tube housing onto the bellhousing. Slide the prop shaft in from the back and reinstall the snap ring. It’s light and easy to maneuver.
Old 12-31-2017, 10:25 PM
C U IN REARVEIW
Even if you use alignment tool for clutch plates?
To Mantic clutch install questions...
Old 12-31-2017, 10:29 PM
Tech
Tech's Avatar
Yes. The plastic alignment tools take some practice and a little luck to get perfect. Mine don’t fit as tightly as the end of the prop shaft.
Old 12-31-2017, 10:34 PM
C U IN REARVEIW
If they dont line up correctly, would the shaft just not slide in?
Old 12-31-2017, 11:39 PM
Tech
Tech's Avatar
Multi-disk clutches are a little trickier. Sometimes it’ll seem like the prop shaft is in far enough that it should slide in the rest of the way but it doesn’t easily. If you force it when it is not perfect, you can damage the disk. IDK if the stud trick will work as well as my method, but if you do it my way, it’s nearly impossible to screw it up.
Quick Reply: Mantic clutch install questions...
