Roll racing A8
Received 1,817 Likes
Roll racing A8
What's the trick for getting the A8 into the power band for roll racing?
When I use the paddles to down-shift in auto mode, often the temporary "manual shift mode" doesn't time out soon enough for the transmission to make the next shift automatically, so it hangs on the rev limiter.
I'd rather have the trans in full auto mode after the start of a "race", because that seems to be faster.
Will it work to select "manual" on the console shifter, downshift with the paddles, start the race, and immediately move the console shifter back to Drive? Will that put it back into auto shift mode without any time delay?
Sorry for needing to ask, it's too cold here right now to experiment for myself.
M7 :-)
This theory has worked for me for a while, as long as you time it correctly. The second I get on the gas (while in the desired gear), I immediately manually move the console shifter back to drive and let the car do it’s thing. Works like a charm
The following 2 users liked this post by ArcticZ1:
tail_lights (01-10-2018),
Warp Factor (01-09-2018)
Very little do do it being an auto. You have to wait for the computer to react to your input. It seems many just drive in manual mode to avoid AFM anyway.
That works fine from a standing start, where the computer will already have you in the lowest gear. Putting at 40 mph or so, the computer might have you in 5th, when 2nd or 3rd is where you need to be for maximum acceleration.
Think if the transmission left the line at the dragstrip in 3rd, and then shifted to first. It would cost some serious time.
If it's that close you probably need more power. In my experience I am faster letting the computer manage the shifts. Whatever you gain in the little delay get for downshifts could be made up by adding power, traction, reducing aero, etc. The computer will nail it 100% of the time, figure out what speed the car rolls on best from and suggest that as your starting speed. Your opponent will most likely not though that far ahead
I think what you are trying to do is get the car in performance algorithm mode.
The key to this is you got to have the car in either sport or track mode. It won't work if the suspension mode is in Tour.
When you are around the speed you want to roll race at, you will almost go the floor and immediately left off. You will see a message come up saying "performance algorithm mode"
At that time, you will have about 10 seconds before it jumps out of that mode. When you are in that mode, you just hit it and the computer will do all the shifting from then on.
Leave shifter in Auto, paddle down once to activate manual mode overide, paddle down again and hold for lowest possible gear selection.......make the hit and immediately paddle up and hold so it shifts and goes back into auto mode.
Paddle-up (shifts once) and hold (puts system back into auto and it will make the next shift for you). Once you see "D" re-appear in the display (rather than the gear number) you can let go...it take about 2 seconds.
Your illusions of grandeur with the C6Z in every one of your posts is entertaining... BTW, I beat a head/cam C6Z from a 45 roll in my C7Z A8 this weekend...I had a car gap on him by 150... By your calculations, he should have RAPED me....
The A8 on the stock tune is very picky about starting and shifting points. The trick is to pull the shifter down into Manual, paddle to the gear you want to start in, as SOON as you nail it, shift it back to Drive and let it shift itself. If you are starting in 2nd, you can not start faster then 45 mph, even though you have plenty of RPMs, the computer/trans will not complete the 2-3 shift before its on the limiter.
The gear spacing for roll racing is awkward. 2nd gear starts are too high for anything over 45 mph.....And 3rd gear starts are WAY too slow for anything under a 75 roll.... You would think with 8 speeds, roll racing gear selection would be easier but..its not the case.
I raced a Paxton supercharged ACR Viper this weekend in Mexico, he wanted to start from 60 mph, which ended up being 55 mph....I was in 3rd and it just KILLED me on the start...he went through 2nd and some of 3rd before I even got through 3rd.... I still tied him at 143 mph though... He was quite surprised....(as was I...LOL)...Notice how long my car was in 3rd...starting at like 3400 rpms...
If we had gone from a 45 roll with me in 2nd, he would have been in trouble.
Similar practice. I slide shifter into M, hold left paddle until it goes to lowest gear. Smash the loud pedal and slide shifter into D before the next shift and let the trans do it's thing.
2017 C7 of the Year Finalist
I love this mode.
