C1 Trunk key lock
Old 01-15-2018, 04:26 PM
dennis6605
dennis6605's Avatar
Default C1 Trunk key lock
I've done a search and can't find any info.
I went to a car show today and when I tried to open the trunk to get our lawn chairs out the key would turn but not release. I think the latch on the end of the cylinder must have came off. Any ideas of how to get it open with out a lot of damage. Its a '59 if that means anything.
My wife put some fruit in there and I would really like to get that out of there.
Thanks Dennis
Old 01-15-2018, 04:36 PM
dcamick
Tether Man
Support Corvetteforum!
dcamick's Avatar
Received 2,014 Likes on 1,039 Posts
2019 C1 of Year Finalist (appearance mods)
Thanks Dennis
Push down on the deck while turning the key.......Might help!
dennis6605 (01-15-2018)
Old 01-15-2018, 04:41 PM
427390HP
427390HP's Avatar
This has happened to others. Here are three threads that have discussed the various problems and solutions:
https://www.corvetteforum.com/forums...on-t-open.html
https://www.corvetteforum.com/forums...unk-stuck.html
Good luck in getting it open.
Terry
Old 01-15-2018, 04:42 PM
dennis6605
dennis6605's Avatar
Tried that
Old 01-15-2018, 04:46 PM
Geralds57
Geralds57's Avatar
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
A car show in Indiana today? It must have been inside. If the rod came off, you’ll probably have to drill out the lock and use a long screwdriver to open the latch. I had to do it one time but it was a 57 and I couldn’t punch out the emblem. Hopefully pushing down on it will make it open. Good luck.
Old 01-15-2018, 05:59 PM
dennis6605
dennis6605's Avatar
Originally Posted by Geralds57
A car show in Indiana today? It must have been inside. If the rod came off, you’ll probably have to drill out the lock and use a long screwdriver to open the latch. Hopefully pushing down on it will make it open. Good luck.
I wondered if anyone would catch on to that. I'm in Harlingen TX. I went to a "Winter Texan Appreciation Day" car show. Entered in a indoor show next week in McAllen TX.
Got a expensive lesson today. My cleaning kit bag was jammed against the lock. I should have just went out and gotten up to speed and jammed on the brakes. Knocked the emblem out and got in the trunk. Busted up a new emblem and ring. New parts come to around $260 with S&H.
One forum member suggested knocking the emblem out with my fist. I sure don't want to **** that guy off as I had to hit it several times with a 2 lb. ball peen hammer.
Thanks guys for the suggestions,
Dennis
Old 01-15-2018, 09:53 PM
mmaturo
mmaturo's Avatar
My lock did the exact same thing as the original poster...(I commented in the posts linked) I tried about everything. Handed it off to guys doing other work on the car to take a shot at it. They popped the emblem out with no damage. I couldn't bring myself to do it. The lock cylinder/latch was misaligned/bent and had bound up.
Old 01-16-2018, 04:54 PM
dcamick
Tether Man
dcamick's Avatar
Dennis
Unbelievable.....I thought that stuff only happened to me!!!!
Old 01-16-2018, 05:45 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I can push the emblem out of my '61 with my hand, i don't need to punch it.
The three pins on the ring are really too small for the speed nuts, and the nuts just slide off the pins with moderate force.
Look at it this way, you have a brand new emblem and ring now.
Doug
Dennis
Old 01-16-2018, 06:28 PM
0Corvettes by George
Former Vendor
Corvettes by George's Avatar
Yes,
I was able to “pop off” the trim ring thereby saving my Center emblem and backing. One prong did break, but a much cheaper piece to replace.
Incidentally, the spring broke which allowed the lever to dislodge—disappointing in that it was a new lock/spring set. Replaced with old original spring and so far so good. Wonder if the replacement springs are of lessor quality?
G
Old 01-17-2018, 04:35 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
I pushed the emblem in once... now I have an electric trunk latch...
Bill
Old 01-17-2018, 04:59 PM
Former Vendor
My current build will have an electric lock��
Old 01-17-2018, 05:29 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
there is a Ford latch that will work with 2 out of the 3 bolts used (what I used and it works fine..., the 2 bolts are in the same location as the GM ones), and a Firebird one that has 3 bolts like the manual latch. the Firebird one is a bit pricey..
Bill
Old 01-17-2018, 05:32 PM
AZDoug
AZDoug's Avatar
Bill
It still works with a key, too,
right?
Old 01-17-2018, 05:38 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
right?
yes... uses the original lock assembly and tail piece
Bill
Old 01-18-2018, 07:23 PM
6D2148
6D2148's Avatar
I think I'll put emblem in with "O" rings instead of speed nuts. Chip
Old 01-18-2018, 07:40 PM
Captain Bud
Captain Bud's Avatar
2020 C1 of the Year Finalist - Unmodified
Default qhat year?
What year ford electric latch did you use?
Old 01-19-2018, 03:02 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
it appears to be kin to this one...
https://www.ebay.com/itm/1965-75-FOR...NaSzOn&vxp=mtr
I believe it is eckler that had a 'kit' using a GM latch, you might want to check with them to price shop....
Bill
To C1 Trunk key lock
Quick Reply: C1 Trunk key lock
