[C2] What is the best way to fix front dented crossmember
Received 6,945 Likes
2015 C2 of Year Finalist
at one time someone sold a tool just for that repair
Vendors sell the tool. IIRC Corvette Central sells them.
Sometimes members loan the tool back and forth.
Vettegeezer (01-17-2018)
I have also seen photos of cutting out the lower plate and pounding it out to get it back to shape and then welding it back into the frame. Then grind the welds smooth.
This is what I did on my 70. It wasn't hideous, seen much worse, before the repair but it bugged the hell out of me. A few hour job on your back and it's no longer a problem on a completed car. Just be sure to prepare yourself for all the weld spatter raining down.
I posted a yr or so ago showing my friend using the tool. Do a search on here.
FOUND IT. Scroll down post
https://www.corvetteforum.com/forums...ber-dents.html
Some before and after pics of this tool being used would be great. There are dents and there are DENTS!!! I figured these tools were for guys without any fabbing abilities so I didn't bother spending the unnecessary money. I find it hard to believe it can bring wrinkled metal back to an acceptable level of straightness.
That works great for the really large dents. For the small ones, I simply heat the metal up with an A&O torch and use a dent puller. I've done it both ways and it's very easy, especially with a bare frame that's upside down on jack stands as I hate overhead welding.
