[Z06] wheel bearing torx bolts specifications
After I had a local shop remove the ball joints and wheel bearings from my spindles, the torx bolts did not make it back, and can not locate them... I need at least 6 apparently. I still have to unwrap the rear axles to see what is there....
Does anyone have the specifications for them?
Or alternatively some laying around they don't need?
I am looking for the bolt specification, it has a "torx" head
I need size, or somewhere to order it. I saw one vendor had a kit but it seem a bit costly....
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
The 3 torx bolts that hold the hub to the knuckle are 12x1.75x54. The GM part number is 10414261 if that helps.
srshaw3 (01-23-2018)
