Pulling NPP fuse on my 2018 Grand Sport
So I've read a lot of threads about people pulling their fuse to effectively leave open the exhaust valves. I've looked in my owners manual and found mine (for my year and model) to be fuse # 42. Since it's such an easy thing to do (pull/replace the fuse), I'd like to see / hear the difference, but my silly/dumb question has more to do with *when* to pull the fuse (when the car is running or when the car is turned off and not running)? Or does it matter? Thanks.
CADbrian (02-14-2018)
I don't know for sure, but I was under the impression you can change your default exhaust status under the settings on your info screen. No need to pull any fuses. I haven't taken delivery of my car yet, so I can't guarantee this.
By pulling the fuse the valves stay open 100% of the time no matter what mode you are in. That is the only way to keep the valves open all the time in any mode.
bsterling9 (02-14-2018)
Received 8,928 Likes
I leave my Z06 engine sound management set in track mode all the time unless I want to hear the radio or am on a long trip. Then I set it to Stealth.
All you have to do is push the settings icon on the center display and go to Engine Sound Management and choose track. Voila, Noise.
OP: if you want to pull the fuse only do it when the vehicle is turned off. That is the standard way of doing things involving electronics.
Bill
True. However, there is no need to pull the fuse to get the valves to stay open all the time. With Engine Sound Management set in track mode the valves are open all the time without pulling the fuse. If you turn off Engine Sound Management it also puts the exhaust in track mode and the valves stay open all the time as well.
All you have to do is apush the settings icon on the center display and go to Engine Sound Management and choose track. Voila, Noise.
Bill
Bill
The following 4 users liked this post by dvilin:
Bill
Bill
I think I'll try it using the Engine Sound Management set in track mode and see what happens. Then, if I determine that I'm not hearing what I want and when I want it I'll consider pulling the fuse.
I've read enough threads to presume there are some differences across the C7 model with regards to how to effectively leave open the exhaust valves, so I'll share my results for those whose model mirrors mine.
Thanks to all.
Thanks to all.
St. Jude Donor '09
I've played around with my fuse #42 a little. Even in Track mode you can hear the valves open at a lower RPM than Sport mode. To me it was a little annoying, so right now I'm running with it pulled. It's a subtle difference, but I like it better now. I do like being able to control through the exhaust sound management and mode select, but it's something fun to play around with (pulling fuse). I may put it back in when taking long road trips, but right now it sounds just right.
And yes, as already advised, pull with engine off. Oh . . . '17 GS here.
RDBVETTE (02-16-2018)
I've played around with my fuse #42 a little. Even in Track mode you can hear the valves open at a lower RPM than Sport mode. To me it was a little annoying, so right now I'm running with it pulled. It's a subtle difference, but I like it better now. I do like being able to control through the exhaust sound management and mode select, but it's something fun to play around with (pulling fuse). I may put it back in when taking long road trips, but right now it sounds just right. And yes, as already advised, pull with engine off. Oh . . . '17 GS here.
You said,
You said,
You said,
You said,
Sorry for the ridiculously parsed questions, but knowing exactly what you mean helps me to figure out what I'd like to do. Thanks.
Received 3,439 Likes
Remove fuse 42 and exhaust open at all times. With fuse in, and using driving modes in Sound Management such as Track, the flaps will close under 1,800 RPMs. And actually if in Sport with the fuse in flaps will close at about 2,000 RPM. Noise ordinance is the issue in regard to this. As I stated, remove 42 and open at all times regardless of RPM.
DWG (04-29-2018)
They do close, even in track mode in order to meet federal drive by noise standards.
See this thread for a more detailed explanation: https://www.corvetteforum.com/forums...ck-result.html
I pulled mine and am happy with the sound. If I were going on a long road trip, I would reinstall it and have control.
The following 3 users liked this post by Boiler_81:
If the car is running and the valves are closed and you pull the fuse, they will open. You will hear the difference.
If they are already open (sport or track mode) and you pull the fuse, nothing changes because they are already open. You wont hear any difference.
Pulling the fuse just prevents the valves from closing under low pressure/load conditions such as letting off the throttle or "coasting".
If you want the valves open 100% of the time, pull the fuse or get a mild2wild switch.
Has anyone experienced adverse consequences of pulling this fuse? For example, this guy on YouTube lays out a pretty compelling case NOT to pull the fuse.
Pulling Fuse 42 (in his case) generated the following issues on his diagnostic report:
I may just decide to control the sound via the Engine Sound Management and live with the valves being closed at the lower RPM's. If what this guys is reporting is true, the risks are not worth the rewards to me.
Are there any of you out there good with electronics that know if what he is reporting is true?
- loss of communication with steering wheel module: measure position angle and rate of turn
- loss of communication differential control module: locks axles to differential, change the gear ratio applied to axles, amount of torque applied to the drive line
- loss of communication electric brake control module: controls brake system, activates ABS and traction control
SilverGhost (03-19-2018)
this guy on YouTube
this guy on YouTube
I'm wondering if there's anything else the U-tuber may have altered in the C7 that caused the issues on the report and he's only assuming it was removal of fuse #42?
