C7 front license plate - removable??
In Wisconsin most law enforcement don't bug you about front license plates, EXCEPT the State Patrol. Well, I have one living right on my way to town and he is a real Gung Ho.
Has anyone use the Corvette Front License Plate Remote Mount, Altec, ''Show & Go'', 2014-2018 from Eckler?
Either manual or power. I would love to use the power option style.
2017 C7 Z51 with factory added splitter.
Thanks
Thanks
Popular Reply
02-17-2018, 10:25 AM
The powered versions do not work well with splitters or on any C7 for that matter.
I highly recommend the manual-remove, Sto-N-Sho referred to by Borntorun above. They have 2 versions, one for the Z06, GS, or aftermarket splitter-equipped Stingrays, and another version for non-splitter equipped cars.
It's a very high quality piece, and plate is on and off in a couple of seconds, and there's nothing to fail.
Link here:
http://bigmikesperformanceparts.com/...ffects-sns50b/
Link here:
Check below. More info on front plate laws and plate mounting than anyone could ever need. Also may try search under Altec.
https://www.corvetteforum.com/forums...late-laws.html
What I want to know is, has anyone installed any one of these mounts from Eckler.
What ever- dude, just trying to help you out. There's quite a bit of discussion in that thread on the Show&Go if you took the time to look. Also as stated, if you search Show&Go and/or Altec lots of info.
Old Racer (02-18-2018)
I used the Sho N Go plate holder on my 04 for years and loved it. I had the remote model and was great to flip down for cruise nights . I purchased a 17 GS and Sho N Go can't be mounted due to angle of front splitter. I purchased the Sto n Sho plate holder for my GS after recommendations from members on the forum. Its a manual release holder and is working out great easy to remove and NO scraping. Here is a picture of it mounted under my GS. I ordered from Big Mike goggle either holder or Big Mike and it will show up. There is different model for Stingray or GS/Z06
Link here:
Link here:
Sto N Go
I just ordered this Sto and Go:
2014-2017 C7 Corvette Stingray & Grand Sport Quick Release License Plate Bracket Sto N Sho
$84.99
Very nice and well made.
Ron
$84.99
Ron
The last 3 posts are all talking about the same product, and to avoid confusion it's STO N SHO, not "go."
Hi - I live in Neenah WI so have the same concern about getting stopped. I had the same question about the unit. It looked good until I read a review of it on Amazon. The reviewer said it worked fine but got damaged going over some high/low spot in the road - hung down and damaged plate "With this unit installed you only have about 2-3 inches of ground clearance. A pothole or an uneven surface will cause the unit to hit the ground"
Received 3,439 Likes
Link here:
Link here:
Thanks Joe. XPEL Ultimate should be going on by the end of next week, if my guy can get the damned Lambos finished and out of his shop.
joemessman (02-17-2018)
Freerider969 (06-09-2021)
Pictures do not do it justice.
Here's my standard spiel about not mounting anything lower than the splitter even if it is removable...
So just used the GM grille mount, with a little trimming..
Can be removed with screw driver on 2 fasteners through holes in the plate.
The following 2 users liked this post by TEXHAWK0:
Freerider969 (06-09-2021),
Not sto n sho but I use the removable plate from Zip Corvette's. Item number x3452. Works well..
I'm less likely to hit anything with no splitter than you are with your splitter. My standard spiel is that splitters are nothing but trouble in street use and serve no useful purpose other than looks if you actually like that look.
However, another way to look at it, is that the Sto-N-Sho is an excellent splitter saver, since it serves as an early warning that your splitter is about to be damaged beyond repair. It's far cheaper at $85 than replacing that expensive splitter.
Last edited by Foosh; 02-17-2018 at 01:41 PM. Reason: Quote added due to intervening post.
woodsguy (02-18-2018)
Foosh (02-17-2018)
That looks good. What kind of saw did you use to trim it? Are the edges smooth?
Thanks
Thanks
