Removing/Installing A-arm Bushings
Been beating my head against the wall for years when this job comes up.
Has anyone found an easy (easier) way to do this. Or maybe some tricks?
Thanks in advance!
Thanks in advance!
Received 1,920 Likes
I'm in on this question.
I'm thinking that the easiest way might be to take them to a suspension specialist and have them press the old ones out and install new ones. I'm thinking that the frustration available that comes with this task may likely exceed my infinite patience and long years of stupid experience.
I wonder if the old timey suspension shops still exist?
I drive the old ones off/out with an air chisel and press the new ones on with a 2 ton press making sure you have a spreader between the two openings to keep the A-arm from collapsing. Ive been doing this for years. Very fast and simple.
I use my shop press and various large sockets to press them out and back in. If you don't have one its better to just out source this task.
Received 3,443 Likes
I've been doing this for decades as well. In fact, I usually buzz the new ones back in using a blunt tip and a big socket. Very fast and simple with an air chisel with the right bits.
Watch You Tube videos to see how its done. I used a hammer and chisel to collapse the bushing sides and drove it out with a hammer. The video shows putting a new bushing in with a hammer but I like the press idea. This was my first time and it was not difficult at all.
Thanks have owned for 16 years , after bushing replacement could really tell they needed to be replaced , car steered better tracked straighter and did not make noise when going in a out of driveways, cost of bushings and install was 425 dollars well worth it .
Looks like a balljoint press but one of the ends is a "C" instead of an "O". This is from an Amazon ad, but lots of places sell them as "Control Arm Bushing Press".
I do need to check out a youtube video to see if I'm willing to attempt this job. Not sure.
Love the Chevelle. Here's a pic. of my 70 LS-6. Sold it years ago for $2000 and it had less than 30K miles. Who would have known?
Man what that could be worth now but who knew, seems like we all have a car we wished we could have kept. problem is life got in the way kids, houses, work, the list goes on.
Like others said, if you have a press, its easy-peasy and 1/2 hr job to R&R them all. You need some large sockets, as well as spacers to ensure you don't bend the control arms (which a shop press can very easily do if you don't use spacers). You'll need 2 different sizes of spacers because of the difference between the upper and lower control arms. I made my set from heavy wall pipe. Fyi Bill
Received 1,521 Likes
C2 of Year Finalist (appearance mods) 2019
I don't want to sell you mine because I loan them out to the C1-2-3 guys around here. In fact I just got them back last week from a friend.
They are easy to make ... if you have a bandsaw to split the pipe. If you're stuck, I can make you a pair.
