New GS Owner....Need suggestions!
I am in the process of buying a 26K mile 2013 GS and am interested in "must do" mods/tweaks.
I already plan to change every fluid just to be safe along with plugs/wires.
Are there any quirks or issues I need to be aware of or very effective mods anyone suggests?
Thanks in advance!
Thanks in advance!
Received 2,683 Likes
2018 C6 of Year Finalist
Supercharger.
Pro Mechanic
Received 3,952 Likes
first item would be to ensure tire condition and age.............
alignment, as some wear insides of front tires quickly............
rest of the mods are what each individual wants to personalize their vehicle to sit their wants / needs..............
Received 1,596 Likes
Welcome to the club ! If you have a 6MN a MGW shifter is a must.
I don't think there are any "must do" mods for a 2013 GS. Car is sweet as is. Change oil and filter and check fluids sure but no need to rush to change all fluids much before time/miles recommendations in manual. Possible exception is brake fluid because over time it could absorb moisture. If you want to change your car suspension, motor work, supercharger etc. think about what is the purpose for doing so like tracking etc. but whatever get the right technicians and parts to do any serious mods. Enjoy your car!
I recommend putting a cover in the center console if you put electronics in there. Also the drink holder. Both tend to get warm and Top Flight Reproductions sells some cheap (in price) kits that work.
I also wouldn't put any drinks or stuff in the trunk that can explode as it does get hot back there. TKO Performance has a blockit mat that works great. A partition would be nice to keep the luggage in the back also.
There is a lot you can do to change the car but it all depends on what you like/desire to keep warranty/etc.
St. Jude Donor '22-'23
If it has the factory original brake pads you might want to change those out. Even though they work great they are messy as hell and are subject to squeal quite a bit. Do some research here on the forum about alternatives.
Otherwise like others have said, as long as the vehicle wasn;t abused, there should be little that NEEDS to be done. Drive it and enjoy it.
Congratulations on your wise purchase.
Finally a good answer. The battery tender is the only thing the factory seems to have missed because they made it an option and not standard.
You will see lots of other answers from people who have bought snake-oil products and have a psychological issue acknowledging they just wasted money. There are NO "must-do" additions to these cars. The factory spent a lot of time and money getting them right from the start. Until you start spending thousands, any performance mods are worthless. Appearance mods are subjective. The Battery Tender "mod" is only valuable if you intend to keep the car more than a few years. But if you keep the car a while you can save replacing a battery every 2-3 years and, if used all the time, change that to changing the battery every 7 years. That will save the cost of the Battery Tender.
BTW, you might want to start by reading the Owner's Manual https://my.chevrolet.com/content/dam...tte_owners.pdf. That will save you the cost of plugs and wires by informing you that GM thinks the plugs should last 160K miles not 26 and the wiring may last even longer. Or you could just start throwing money at this car changing to the latest greatest snake-oil plugs and wires and then, when the car starts performing worse, come back and we can tell you about how GM engineers DO know their business.
c5arlen (02-25-2018)
The insulation kit for the center console and drink holder is surprisingly effective. If you’re going to store anything in the console (cellphone, charger, mini flashlight, etc) you’ll be glad you have this.
http://www.topflightrepro.com/corvet...products.shtml
Enjoy the ride and post some pictures!
Received 1,136 Likes
I agree with changing the fluids but the plugs and wires should be fine till 100k miles. Alignment is also key since the factory setting is too aggressive and wears the tires quickly. Other than that the GS is a beast!
The insulation kit for the center console is surprisingly effective.
No need to get exotic right off the bat, fluids for sure, alignment and for the tunnel heat here is the no frills, wont break the bank fix and it definitely works
NSF
https://specialty-auto-materials.net...e-heat-shield/
NSF
