C7 Corvettes for Sale Private Classifieds, Used C7 Corvettes For Sale, and Modified or Stock Corvettes
FS: 2016 1LT M7 710rwhp - White Dallas, TX
Old 03-19-2018, 01:35 PM
555ctsv
555ctsv's Avatar
Default 2016 1LT M7 710rwhp - White Dallas, TX
***Car has been sold to a great buyer 5/2/18***
Hey guys,
Bought a house and a truck to daily and now the car just sits in the garage. I need to mod my house and the car is done so looking to sell it.
2016 Corvette Stingray 1LT
7-speed Manual Transmission
16,800 Miles
Dallas, TX
717rwhp
Asking: $48,500
Currently the car makes 695rwhp on 93 Octane and 717rwhp on E85 (@56%). Has high side and low side fueling upgrades so fuel psi is no issue.
It had previously made 773rwhp on 93 Octane with a smaller pulley, but I wanted to play it safe and swapped out the 3.6” pulley for a 3.8” and added the E85. You could put the 3.6” pulley (included) back on and with E85 likely break 800rwhp but that may be too much for stock internals long term.
Engine Mod List:
Camshaft w/32% Fuel Overdrive (21st Century Muscle Cars Spec)
LG Motorsports 1-7/8” Headers (High Flow Cats Included, not currently installed)
LG 3” X-Pipe to Factory NPP Mufflers
LT4 High Pressure Fuel Pump
LT4 High Flow Fuel Injectors
Cordes Performance (CPR) Low Pressure Fuel System
Alky Control Methanol Injection Kit (Dual Nozzle)
A&A Supercharger Kit w/Upgraded V3Ti Head Unit (Black Finish)
AFR500V2 Wideband – Ballenger Motorsports w/NTK O2 Sensor
Dash Logic / Dash Control (Shows Ethanol % and other parameters on Factory Dash)
Other Mods:
Z51 Front and Rear Sway Bars
Z51 Shocks
Z06 Front Grill w/Brake Cooling Ducts
Z06 Stage 1 Front Splitter
Z06 Rear Quarter Panel Vent Ducts
Showstoppers “ZR51” Rear Spoiler
Showstoppers LED Corner Marker Lights
Carbon Flash Painted Emblems Front and Rear
Carbon Flash Painted Side Skirts
Z06 Replica Wheels (Black): Front & Rear 18”/19” w/Nitto NT555 G2 Tires
Extra Rear Set Z06 Replica Wheels (Black): with 305/30/19 NT05R Drag Radials
OEM Suede Shift ****
BlockIt Sound Deadening Matts
Below is the history of the car/mods:
Purchased car @ 14 miles - 6/22/16
Installed TSP Headers
Z06 Front Grille
Z06 Front Ducts
Z06 Front Splitter
Z06 Rear Quarter Panel Ducts
ZR51 Rear Spoiler
LED Corner Markers
Smoked Corner Markers, Rear Reflectors
Black Front/Rear Emblems (replaced chrome)
Sunvisor Airbag warning decals
Installed Hinson shifter - 7/1/16
Window/Windshield Tint - 7/6/16
Uninstalled TSP Headers
Installed LG Motorsports 1-7/8" Headers w/Cats
Side Skirts Paint and Install
Dealer update Infotainment software - 7/20/16
Dealer Mobil1 oil change @ 860 miles - 7/20/16
Installed Z51 Sway Bars Front & Rear - 7/23/16
Lower Front of Car - 7/23/16
Installed AFE CAI @ 1,076 miles - 7/30/16
Uninstalled Hinson shifter reinstalled stock shifter - 8/6/16
Installed MGW shifter - 8/22/16
Installed BlockIt Sound Deadening Mats - 8/27/16
21st CMC Installed Camshaft, LT4 HPFP, LT4 Injectors, Flex Fuel Sensor, and tuned @ 2,546 miles - 9/26/16 to 10/7/16
Uninstalled AFE CAI @ 2,631 miles - 10/8/16
Removed Catalytic Converters - 10/15/16
Installed NPP Exhaust Switch - 10/15/16
Installed A&A V3Ti Supercharger Kit @ 3,325 miles - 10/28/16
Installed Alkycontrol Methanol Injection Dual Nozzle @ 3,325 miles - 10/29/16
Installed Cordes Performance Low Side Fuel System @ 3,325 miles - 10/30/16
Changed Engine Oil Redline 10w40 @ 3,325 miles - 10/30/16
21st Century Muscle Cars Tune = 773rwhp/592rwtq @ 3,408 miles - 10/31/16 to 11/3/16
NTB Alignment @ 3,517 miles - 11/6/16
Changed Supercharger Oil @ 3,552 miles - 11/6/16
Exhaust Clamps Tack Welded 11/7/16
Rear Tires Nitto NT05r Installed @ 3,722miles - 11/10/16
Fuel System Activation Blue LED Installed - 11/11/16
Front Tires Nitto NT555 G2 Installed @ 3,925 miles - 11/11/16
WannaGoFast - Sulphur Springs 1/2 Mile Event - 5 passes made - 11/12/16
3.8" Pulley Swap - Flex Fuel - Retune @ 4,450 miles 11/30/16 to 12/9/16 (HP Tuners Software issue. Tune not completed)
Installed Boost Gauge, Oil Dipstick Handle Cover @ 4,874 miles - 12/17/16
Installed Wide Band Sensor, Front Wheel Spacers w/ARP 100-7708 Studs, LED License Plate Lights @ 4,918 miles - 12/27/16
Installed Fuel Pump Override Switch, Uninstalled MGW Shifter, Installed Stock Shifter @ 5,268 miles - 1/7/17
21st Century Muscle Cars Revised Tune 3.8" Pulley + E85 = 717rwhp/641rwtq @ 5,281 miles - 1/11/17
Installed Suede Shift **** onto stock shifter
NTB Alignment @ 6,070 miles - 2/8/17
Changed Supercharger Oil @ 7,670 miles - 4/14/17
Changed Engine Oil Redline 10w40 @ 7,670 miles - 4/14/17
Installed Z51 Shocks Front & Rear @ 10,647 miles - 7/22/17
Changed Supercharger Oil @ 11,051 miles - 7/30/17
Changed Engine Oil Redline 10w40 @ 11,051 miles - 7/30/17
Replaced A&A Air Filter with Green Air Filter @ 11,353 miles - 8/6/17
Flushed Brake System and Clutch Fluid with Castrol SRF @ 12,367 miles - 9/9/17
Replaced Low PSI Fuel Line - Check Valve Sound PN 12618338 @ 13,871 miles - 10/30/17
Changed Supercharger Oil @ 14,547 miles - 11/11/17 (Oil was very dirty, emailed A&A)
Changed Engine Oil Redline 10w40 @ 14,547 miles - 11/11/17
Sent Supercharger to A&A/Vortech for inspection @ 14,572 miles - 11/21/17
Installed new LT4 HPFP, Low PSI Fuel Line w/Check Valve, High psi pipe, .060 lashcap for preload on pump @ 16,158 miles - 1/13/18
Installed Rebuilt V3Ti Supercharger & New A&A Belt Tensioner @ 16,158 miles - 1/13/18 (Vortech reported original tensioner was too tight)
Old 03-19-2018, 08:26 PM
555ctsv
555ctsv's Avatar
A few more pics
Old 03-20-2018, 11:19 AM
555ctsv
555ctsv's Avatar
Here's the latesr dyno sheet I have. The 773rwhp was before we put the bigger pulley on and added E85. Safety first!
Old 03-22-2018, 05:33 AM
Blue Vert 91
Blue Vert 91's Avatar
You are obviously a meticulous individual. What is the issue with sending the blower off to be checked? What was it doing to make you want to disassemble it and have it evaluated?
Old 03-22-2018, 10:13 AM
555ctsv
555ctsv's Avatar
I heard a noise which some would just attribute to direct injection. I pulled the belt and checked all the pulleys and tensioners on the blower and the oem accessories. I replaced the oem tensioner as i had heard those can make some noises, that didnt solve it. Then i replaced the low psi fuel feed line $40'ish and that solved the sound for about a month. (Google service bulletin pip5395b)
Annnyway the sound came back after about a month. Then the day before a half mile event i signed up for i went to change the engine and supercharger oil (note the are completely separate) and found some metal bits in the supercharger oil (not in the engine oil!)
Car ran fine but i didnt want risk it so lost my 1/2 mile entry fee and pulled the blower. Vortech said the belt tensioner must have been too tight and it needed t be rebuilt. I was about 1 month outside the A&A warranty period but they offered to split the cost of the rebuild with me and sent me a new tensioner.
This was all during December so it took a while to have it rebuilt. Once it came back all fresh and new i replaced the LT4 high psi fuel pump following the guideline on the forum for measuring the preload clearance and adding a small .060" lashcap, replaced the low psi feed line again just for good measure, and reinstalled the blower and all has been great for the last 2 months and 700 miles.
There's another half mile event im signed up for in April so i wanted to get everything in tip top shape for that
ron landgraf (04-17-2018)
Old 03-25-2018, 06:23 PM
onebadcad
onebadcad's Avatar
GLWS, bump for a great car at a great price.
If not listed at ctsvowners, you should do it.
Old 03-26-2018, 07:38 PM
555ctsv
555ctsv's Avatar
Thank you sir! That's a good idea, i havent visited V owners forum in quite a while, ill have to go check in
Old 04-17-2018, 01:55 PM
555ctsv
555ctsv's Avatar
Bumpksies! Made 4 passes at a half mile even last weekend. I was intentionally holding off on bumping this until i finished that event.
I'll get some better interior images and video up asap
Fresh blower and engine oil change. Also installed a DSX IAT/Baro relocation harness and updated the tune just before the event last weekend.
Spoiler is off the car currently (took it off for the 1/2 mile event). I'll put it back on this weekend
I put the meth and 2nd fuel system activation lights up high on the A pillar. You can see them out of the corner of your eye so you dont have to look down at WOT to make sure they're functioning
Old 04-17-2018, 05:50 PM
bc928
bc928's Avatar
Good luck with sale. Great story told in the mod list with what was installed and uninstalled. Just bought a low mile Z51 and would do many of the same things.
Old 04-17-2018, 07:54 PM
bc928
bc928's Avatar
Crazy question but what kind of MPG do you get on the highway being sane at around 80-90mph?
Old 04-18-2018, 10:24 AM
555ctsv
555ctsv's Avatar
I haven't really logged it but it doesnt seem much worse unless I am running E85. Then it's pretty noticeable.
Old 04-18-2018, 10:33 AM
Vikinglover42
Vikinglover42's Avatar
That's a whole lot of car for that price!! GLWS
To 2016 1LT M7 710rwhp - White Dallas, TX
Quick Reply: FS: 2016 1LT M7 710rwhp - White Dallas, TX
