2019 brake pad dust?
When I bought my 2013 GS I changed my brake pads due to the dusting issue. I have a 2019 Z06 on order, is the brake dust an issue on the new Z06 models?
frankmp (03-27-2019)
Received 8,929 Likes
They dust but it isn't an issue. It is the nature of the beast. There is nothing wrong with brake pads that dust.
Bill
Bill
badhabit_wb (03-28-2019)
If your just driving the car on the street your going to want to change your pads. I recommend the Carbotech 1521.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Adam@Amp'dAutosport.com (04-08-2018)
if you have ocd. like others have said, change the pads. because even a short drive will show a ton of dust. i did the powerstops. perfect solution, i used to clean wheels off after each drive because i didn't want the dust to eat into the clear on the wheels. i haven't cleaned my wheels in about a thousand miles. says a lot.
i have about 10 or so videos of my swap. they're short clips of my trial and error. if you want to see how easy it now it.
Supporting Vendor
St. Jude Donor '11,'13
Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
If interested I will be happy to help you out or you can order online here http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out for your 5% discount.
ZO6/GS part numbers.
F: CT1405
R: CT1718
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
The brake dust goes all over the car. Esp lower under the car and under the doors coating the rims and calipers. Bad stuff!
tzoid9 (02-20-2019)
Oh my yes it is to some Bill if you care about keeping your car clean. I guess I'm one of the only ones that actually even cleans under the doors.
I get a lot of brake dust out of there every time I wash the car but I like stopping better than I hate cleaning brake dust. When pushed hard the low dust ceramic pads don't cut it on hard stops especially if you do it multiple times in a few minutes. Right now I have a set of Ferodo 1.11 pads on the car and they dust the wheels and side of the car before I get more than a quarter mile from the house.
Bill
I wanted to purchase a set of Power Stop Z26 ceramic brake pads for my 2019 ZO6 with steel rotors. When I type in my 2019 ZO6, they say the brake pads don't fit my vehicle. I even tried typing in 1405 and 1718 and it still says it doesn't fit my vehicle. I called the customer service telephone number on Powerstop.com website and they told me it will not fit and they don't have any brake pads to fit my vehicle. What is going on?
Received 3,994 Likes
Supporting Vendor
2019 Z06 pads
