Terrible engine noise, please help!
Hoping this is something small but sounds bad. Checked oil and it was a little low but not out—added a bit more but didn’t help. Kinda sounds like it’s coming more from those front belts than from the engine itself but hard to say.
Thoughts? Any help is appreciated.
1. Is the fan hitting anything?
2. Take a length of rubber hose hold one end to your ear and hold the other end against the alternator, the power steering pump, etc. to determine where the noise is coming from.
Possibly a water pump, alternator or power steering bearing? Make sure all your belts are running true and not hitting anything. Check the bolts on the accessory brackets and fan.
Ya I can’t even get it started now so I wonder if something is stuck. Tried for a minute and got a chemical smell from the car when I tried. I tried moving the radiator fan by hand but can barely get any movement one way or another—is that expected when car is off? Belts appear to maybe be a little forward of true but hard to say.
if you have a clutch fan and cannt move it, the clutch is seized but that will not prevent the car from starting.
Do you see antifreeze dripping from the water pump?
Noise
Start by taking the front belt off and running the engine. If the noise persists, take the second belt off. If you still hear the noise, the problem is within the engine. Jerry
My best guess is the fan clutch has died, and the fan is rubbing the shroud.
Thanks so much! Did some research on clutch fans generally but it wasn't obvious to me...if everything is fine with the clutch fan, should it spin freely or NOT spin freely when the car is off?
Received 2,127 Likes
Spin with just a little resistance with engine off. No free wheeling.
I can't run the video today for some reason. But if fan is really stiff, must be shot like BigBird said. There is fluid inside them things. The fan clutch. Not BigBird.
weird, maybe try now? Just readded link. Video hopefully will make it obvious to someone who knows what the heck is up lol
either the clutch is seized or you dont have a clutch. Need a better look at the fan and what it is mounted to in your next video. Can you get the camera in front of the fan to see the center hub?
No clutch
Oh, sorry I didn’t think to say earlier—this is an automatic, so no user-operated clutch. I assume that makes a difference?
edit: very sorry to have missed this, sorry gang.
Last edited by panamaniac; 04-18-2018 at 04:05 PM. Reason: Edited to make it clear I was sorry
St. Jude Donor '22
this alone is not noisy.
the problem would be it is wobbling allowing fan tips to hit
shroud.
the noise does sound like a fan to shroud issue BUT
that doesn't mean it is.
earlier poster told you to remove fan belts to see
which accessory is making noise.
do some work
the fan clutch may or may not lock up when hot.
shroud.
do some work
shroud.
do some work
loosen all the belts and spin everything by hand you will find it no problem if its driven by the belts , just guessing the most likley item would probably the a/c compressor ,
