Add dry oil sump for 2016 base Stingray
Old 04-23-2018, 11:38 AM
16C7vette
16C7vette's Avatar
Default Add dry oil sump for 2016 base Stingray
Can a dry oil sump be put on a 6.2 base stingray to support a supercharger or can I safely add a supercharger without a dry oil sump?
Old 04-23-2018, 11:41 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Would be very cost prohibitive, but anything can be done. It is absolutely not needed.
Plus you are in the wrong section of the forum. This is the c6 section, not c7 section.
16C7vette (04-23-2018)
Old 04-23-2018, 04:09 PM
Bavaria
Bavaria's Avatar
the 2016 is a C7.
Old 04-23-2018, 04:19 PM
Rebel Yell
Rebel Yell's Avatar
Received 2,639 Likes on 1,702 Posts
Originally Posted by Bavaria
the 2016 is a C7.
Don'tcha just hate it when that happens? But, welcome to the C7 section brother.
OP, with enough money anything is possible. But, I don't think it's necessary to have the dry sump for the installation of a SC. The dry sump is basically set up to keep oil in the engine when you're on the track.
Old 04-23-2018, 08:01 PM
Toombs
Toombs's Avatar
Supercharge it! Dry sump not needed. Keep us updated!
Old 04-23-2018, 09:11 PM
kc stingray
kc stingray's Avatar
procharger on my 1lt. no issues
Old 04-24-2018, 12:29 AM
Foosh
Foosh's Avatar
Received 16,668 Likes on 8,311 Posts
1LT has nothing to do w/ dry sump or not. It's the base trim and option level. You can get a 1LT Z51 and GS w/ dry sump.
To the OP, it would be be ridiculously expensive to convert and more cost effective to trade as cost ineffective as that is too. And yes, you can supercharge w/o dry sump, as long as you're not planning to do a lot of track time/high-G corner carving, and if powertrain warranty is of no concern to you.
Old 04-24-2018, 12:43 AM
16C7vette
16C7vette's Avatar
Thank you, will check back soon when I choose one.....
Old 04-24-2018, 12:48 AM
16C7vette
16C7vette's Avatar
No crazy track cornering, but do like the straight up performance of the SC as had one in a 2013 Caddy V Coupe. What kind of SC did you put in your 1LT? Mine is the Stingray, but it is 3LT.
Thank you much for your reply.
Old 04-24-2018, 12:49 AM
16C7vette
16C7vette's Avatar
Will do and Thank you!
Old 04-24-2018, 07:44 AM
Foosh
Foosh's Avatar
I didn't SC my car, and it's not a 1LT. I was simply trying to explain to someone else that trim level (1/2/3LT) has nothing to do with whether the car has the dry sump engine or not. Dry sump is part of the Z51 package on Stingray, which can be had on any trim level. GS and Z06 all have dry sump engines.
To Add dry oil sump for 2016 base Stingray
Quick Reply: Add dry oil sump for 2016 base Stingray
