Opinions on moving the engine down and to the left in the frame.
I meant to the right in the header.
I as said here before, the engine and tranny, including headers and exhaust, in my 75 Vert are the same ones that I had in my 80 Vette before stuck a stock motor and tranny in and sold it. It all fit in the 80 without any issues whatsoever.
In the 75 Vert the left header flange and exhaust pipe are up against the drivers side floorboard in one place. The exhaust ports are raised on my Brodix heads, so this is the source of the issue. The header are pretty close to the Steeroids bracket also.
I have about 3/8" I can go down if I also move the engine to towards the passenger side about the same amount. I have tons of room on the passenger side to do this.
The mounts are solid, so this would be easy to modify them. It would actually make my vertical alignment of the driveshaft better too. the slight horizontal alignment change wouldn't be very drastic. I have a BTO crossmember that would be easy to modify if I needed to.
The benefit would be to lower the center of gravity and move some weight towards the light side of the car.
What do you think?
Mike
What do you think?
Mike
What do you think?
Mike
What do you think?
Mike
Just modify the exhaust system to fit. If you can do all the other things, then modifying the exhaust system to fit will be easy and quick and you won't affect a bunch of other related and/or attached systems.
Moving the engine 3/8ths of an inch to the right and down is easy and won't cause you a problem. The stock engine location is already sitting on about an inch offset to the right and since you have custom motor mounts and have figured the oil pan will clear everything on the drop I would go for it. Since you won't be moving the transmission mount over you might want to look at how close the fan is to the shroud and things like that up front as it's sitting further forward than the engine mount position and will be more of an offset than 3/8ths of an inch measured at the mount.
C3 of Year Finalist (track prepared) 2019
How much lower? How low is your sump? I have a 1/2" lower than stock sump, and I've grounded it a few times - my car is low though. Otherwise why not, if it looks like the best option, but I agree that changing the exhaust would probably be simpler.
The headers are ceramic coated so heating them up to bend the collector down is out of the question. The oil pan is a 6 quart stock 7" depth so it's not an issue. Other things hanging lower. I have electric fans and there is nothing else that would be affected by moving the engine down and over. Like I said, it will actually make the driveshaft angle better.
Even the air chamber in the L88 hood will still be OK. The hole that sits over the L88 base on the carb was made to big by the manufacturer, so I need to rework it a little anyway.
I have done a lot to stiffen this frame up and upgrade the suspension to improve handling. I'm thinking lowering the center of gravity and moving weight to the lite side of the car will only make it handle better.
Mike
Mike
I was able to elongate the engine mount frame holes to move my motor down and over. I thought that was easier than cutting and welding on my old thicker morroso gold anodized solid motor mounts. I did it to get the 2.5 degree angle on the drive shaft. My custom tranny cross member has elongated holes for positioning the tail shaft. I machined an aluminum block spacer to get the correct tranny tail shaft height
v2racing (04-27-2018)
I was able to elongate the engine mount frame holes to move my motor down and over. I thought that was easier than cutting and welding on my old thicker morroso gold anodized solid motor mounts. I did it to get the 2.5 degree angle on the drive shaft. My custom tranny cross member has elongated holes for positioning the tail shaft. I machined an aluminum block spacer to get the correct height
Mike
