[C1] Lower the engine
When I bought the car there was a little damage to the hood from the carburetor studs making contact. I ground the studs down to flush with the top of the nuts. But still have less than 1/8” clearance and would like to see a little more. (Engine has Edelbrock dual quad and air cleaner)
Since I’ve got the engine and trans out, it’s a good time to address it. I was thinking trim the rubber mounts or elongate the holes at the frame mounts. Even an 1/8” would help some. I’ll be repainting it next winter, and want to make sure there’s no contact afterwards.
Received 1,843 Likes
It might be easier/better to take 1/8" off the carb mounting pads on the intake.
Received 1,283 Likes
You have the engine out, so pull the intake off, remove the carbs and mounting studs, take it to a machine shop and have them shave 1/8 inch (or maybe even a 1/4 inch) off the carb mounting surface.
Or, get a different intake / carb setup that does not sit as high.
Lowering the engine is fixing the wrong problem, and will potentially lead to further problems.
What he said!
Received 3,443 Likes
Lowering the engine will telegraph into other issues: fan clearance problems, transmission mount issues, shifter issues, and probably the worst, incorrect driveline angles. I would change out the intake instead. About an hour's work, with a much better end-product. JMHO.....
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
I'll stick with milling the manifold.
Also giving some thought to a Borla FI setup, but I haven’t done any calculating as far as clearances go
Received 3,043 Likes
St. Jude Donor '05
Actually, I have a mill. So getting it milled is not an issue. But the manifold is already pretty low rise, so I’d rather not make it lower. Doing a little reworking to to the fan shroud, would be minor too. So that’s why I was leaning toward lowering the engine. I’m also thinking, a lower engine in a sports car is a good thing, unless it’s too low for some reason.
You don't need to shim the whole body. There is a lot of up and down movement in the nose. Try just shiming the radiator support. That will raise the hood and will give you more room.
