C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
LSV sipping water not gas
Old 06-22-2018, 07:55 AM
Rkreigh
Rkreigh's Avatar
Default LSV sipping water not gas
well I confirmed yesterday that there is water in the number 6 cylinder
I've been losing coolant and the leak is not yet confirmed, but for sure water is getting in the cyl
I pulled the plugs and did the geyser demo and I was surprised how much water came out. probably 4-6 oz
it was enough to hydro lock the car on startup (that is a very sick feeling)
hopefully it's a leak into the intake, but at this point I'm suspecting a head gasket failure
time to pull it apart, no bueno
Old 06-22-2018, 11:15 AM
ZR1Bob
ZR1Bob's Avatar
Boy, sorry to hear Ron. Never a good feeling but hopefully the hydrolock didn't hurt anything. And I hope it is not as bad as you think!--Bob
Old 06-22-2018, 12:08 PM
Dominic Sorresso
Dominic Sorresso's Avatar
Ron,
If it was 2 or 1 I’d suspect injector housing gasket, but 6. Ugh.
Old 06-22-2018, 02:39 PM
Rkreigh
Rkreigh's Avatar
Originally Posted by Dominic Sorresso
Ron,
I pulled the plenum to have a look and I think its time to take the engine out. I'm worried about the starter bending a rod. the ti rods I have are made out of unobtanium
Old 06-22-2018, 03:58 PM
FU
NCM Lifetime # 982
Support Corvetteforum!
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
What year was the 390 built and @ how many miles are on that engine ?
Old 06-25-2018, 05:11 PM
Goldcylon
Goldcylon's Avatar
Look into Marc Haibeck's Cometic MLS Head gaskets. Only way forward Ron. GC
Old 06-26-2018, 09:40 AM
Paul Workman
Paul Workman's Avatar
I experienced a coolant blowout in the ported IH while making a pass on the drag strip. The motor pumped about a half gallon through a couple cylinders in about 15 seconds and got away w/o any damage to the rods. Keep you fingers crossed!
Old 06-27-2018, 06:20 PM
Rkreigh
Rkreigh's Avatar
I think it was built around 1997 when Larry had 12k on the car. I bought it with 38k miles and just turned over 104k miles so about 92k on the stroker.
I have the plenum and injector housings off and most of the front accessories. Lots of wrenching!!
It will be good to get this thing back on the road.
Old 06-28-2018, 08:05 AM
Scrrem
Scrrem's Avatar
Ron if you need some help give me a shout, I should be around this weekend.
Rich
Old 06-28-2018, 09:53 PM
Rkreigh
Rkreigh's Avatar
Rich
I'm headed up to Katie's on Sat morning and will likely pull the engine very soon. got the top end off and getting ready to pull er out.
time for cam timing 101
Old 06-29-2018, 08:45 PM
ccmano
ccmano's Avatar
Hoping the issue is minimal. I just did the cam timing on mine. Turned out to not be as daunting as I expected. If you have any mechanical ability it’s really not bad. Just make sure you have the right tools. Makes the job infinitely easier. Cam retainers, a crank locater pin and a tensioner reset tool are invaluable.
H
Old 07-10-2018, 01:57 AM
DDSLT5
DDSLT5's Avatar
Here ya go Ronnie: Cam timing 101: insert locating pins. DONE.
Now - onto important matters: get rid of those savage Columbians from your life?
Old 07-10-2018, 07:34 PM
Rkreigh
Rkreigh's Avatar
Hey Doc,
I missed the gathering due to headgasket itus. Hope to have something at least ready for carlisle. for sue I'll be there lord willing.
Old 07-11-2018, 09:46 PM
ccmano
ccmano's Avatar
While a valid way to conduct the factory cam timing. You can be up to 3 degrees off in either direction if you do it this way. There is that much play in the sprocket pins. My driver side Intake cam was a full 3 degrees off at 117 degrees. With that kind of investment in an a engine. Take your time and do it right. It’s not hard.
H
Old 07-14-2018, 03:07 PM
DDSLT5
DDSLT5's Avatar
H
How much power gain after you repaired the timing on that cam?
Old 07-14-2018, 03:12 PM
DDSLT5
DDSLT5's Avatar
H
Also - as you will agree, you still pin the cams if you want to adjust the cam timing slightly at the front of the cam with the sprockets. Without the pins, it is quite difficult to keep the cams from large movements due to the load on the lobes from the lifters. This would be an advanced procedure - not hard for someone with the right tools.
Old 07-14-2018, 03:31 PM
ccmano
ccmano's Avatar
Can’t say. Didn’t do a before and after dyno. Haibeck claims he had a similar offset. He did the dyno and picked up 10hp. He has it documented as well as the entire procedure on his site.
http://www.zr1specialist.com/HAT%20W...0The%20LT5.pdf
H
To LSV sipping water not gas
Old 07-14-2018, 03:46 PM
DDSLT5
DDSLT5's Avatar
H
Marc is invaluable - I highly recommend his shop and his work!
Old 07-14-2018, 03:55 PM
ccmano
ccmano's Avatar
Btw, I’m with you on the shop manual thing. Some people just want answers. They don’t want to learn, research or invest in tools. They can’t be helped.
H
Old 07-14-2018, 04:18 PM
DDSLT5
DDSLT5's Avatar
You're right! And that is why we have guys like Marc! In the long run, it's cheaper for the lazy to just pay a 3rd party to do it right the first time.
Quick Reply: LSV sipping water not gas
